SolaraGuy.com • View topic - Wheel fitment problem with coilovers
Postby arch.HI » Fri Apr 01, 2005 7:39 pm
I just installed my Tein SS coilovers this past weekend but now my rear rims rub the struts. They are sized 17x7.5" with 225/45/17 tires and I believe a 35 offset. It's not the tires that are rubbing it's the actual inside lip of the rim. They've turned green! I was just wondering has anyone else has had wheel fitment problems and if not what size wheel are you running?
2000 Camry LE V6
TRD Supercharged
arch.HI
Re: Wheel fitment problem with coilovers
Postby Jackass-Jeff » Fri Apr 01, 2005 8:45 pm
arch.HI wrote:I just installed my Tein SS coilovers this past weekend but now my rear rims rub the struts. They are sized 17x7.5" with 225/45/17 tires and I believe a 35 offset. It's not the tires that are rubbing it's the actual inside lip of the rim. They've turned green! I was just wondering has anyone else has had wheel fitment problems and if not what size wheel are you running?
35 offset pushes the wheel outward from the body... higher = closer to strut... right?!
Are you dropped TOO LOW?! hahaha... I'm running 18x8 +50 (225/40r18) and no rubbing...
1GR-FE ftw!
Jackass-Jeff
Postby Jackass-Jeff » Fri Apr 01, 2005 9:40 pm
it makes no sense unless my idea of what offset is is backwards... x_x
1GR-FE ftw!
Jackass-Jeff
Postby CASTRO » Fri Apr 01, 2005 9:41 pm
ive had that problem. Running 5mm H&R spacers now in the rear
CASTRO
Postby arch.HI » Fri Apr 01, 2005 11:17 pm
I've tried some 1/4" spacers. They gave me the clearance but then the problem became having too little thread for the lug nuts. Did you have that problem too? if so how did you deal with it? I know it's possible to extend the studs but none of the shops did it.
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby trdkamuri51o » Fri Apr 01, 2005 11:26 pm
just get some small spacers. 1/4 inch is way too much. either that or extended wheel studs./
trdkamuri51o
Postby CASTRO » Sat Apr 02, 2005 12:21 am
arch.HI wrote:I've tried some 1/4" spacers. They gave me the clearance but then the problem became having too little thread for the lug nuts. Did you have that problem too? if so how did you deal with it? I know it's possible to extend the studs but none of the shops did it.
what nuts are you using? my original camry nuts didnt grab as deep as the lexus ones I have now. Im still on the original lugs since the clearance is about the same as stock while using the 5mm spacers. the H&R kit actually came with 5mm longer than stock lugs but I havent installed them yet/dont feel the need to. Becareful with some generic spacers that look like swisscheese, i had them before and they gave me vibrations at high speeds 80+
CASTRO
Postby trdkamuri51o » Sat Apr 02, 2005 9:51 am
yo gimmie the extended wheel studs. :lol:
trdkamuri51o
Postby arch.HI » Sat Apr 02, 2005 3:39 pm
CASTRO wrote:what nuts are you using? my original camry nuts didnt grab as deep as the lexus ones I have now. Im still on the original lugs since the clearance is about the same as stock while using the 5mm spacers. the H&R kit actually came with 5mm longer than stock lugs but I havent installed them yet/dont feel the need to. Becareful with some generic spacers that look like swisscheese, i had them before and they gave me vibrations at high speeds 80+
Where did you get the H&R spacers from? Sounds like they may do the trick.
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby CASTRO » Sat Apr 02, 2005 4:46 pm
i got em from a local speed shop sinc they were a dealer of H&R. its a package set that took like 2 months to get here from Germany! well, the H&R set is hubcentric and it an extremely tight fit. try looking on the site and see if there is a dealer that will sell it to you, if not then look around online.
CASTRO
