SolaraGuy.com • View topic - car leans to the left after tokico/tein upgrade
Postby ironi » Wed Apr 06, 2005 8:20 am
i just had my suspension upgraded to Tokico/Tein a couple of days ago. I noticed that for some reason the car is about a half inch lower on the left (driver) side than on the right. I am guessing this may be because the springs haven't settled fully yet and since there is more weight on the driver side (i normally drive alone), that side is settling faster.
any ideas?
...baby, you're like cross-town traffic...
ironi
Postby cdeez » Wed Apr 06, 2005 9:36 am
i can't call it..i have never seen that happen before...
last standing...
Socalara...
cdeez
Re: car leans to the left after tokico/tein upgrade
Postby swimshady906 » Wed Apr 06, 2005 9:45 am
ironi wrote:i just had my suspension upgraded to Tokico/Tein a couple of days ago. I noticed that for some reason the car is about a half inch lower on the left (driver) side than on the right. I am guessing this may be because the springs haven't settled fully yet and since there is more weight on the driver side (i normally drive alone), that side is settling faster.
any ideas?
Bingp
02' S2000 Silverstone
swimshady906
Suspension
Postby PDX SuperSolara » Wed Apr 06, 2005 9:49 am
The suspension will settle to its final position the first time you roll the car. It doesn't take a while of driving. It shouldn't sit lower on one side because you have always driven alone since these springs and struts are new unless some other part of the suspension is bent or broken or you are really heavy. There is a certain allowance for a variation in height, though it is usually fairly small. You have to measure control arm angle and heights not just at the fender but various areas of the suspension to know where the problem is.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby ironi » Wed Apr 06, 2005 10:02 am
hmm... well, i'm not huge. quite the opposite, really. so i suppose something might have gone wrong during the install. crap.
ironi
Postby Jai_Jai_Binks » Wed Apr 06, 2005 10:10 am
^^ most likely so...it can take at most a week to settle, but it settles evenly. Are you tires all having same tire pressure???
Postby 1st Gen Sol » Wed Apr 06, 2005 1:10 pm
Did your mechanic install both front springs on one side and both rear springs on the other ? ? ? ? I don't think that would be possible but then again it might....... :-?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Spring placement
Postby PDX SuperSolara » Wed Apr 06, 2005 1:51 pm
That is not possible.
2315 SE 11th Avenue
503-236-2871
PDX SuperSolara
Postby bassthrive » Wed Apr 06, 2005 2:58 pm
bump stop wasnt cut?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby ironi » Wed Apr 06, 2005 5:53 pm
1st Gen Sol wrote:Did your mechanic install both front springs on one side and both rear springs on the other ? ? ? ? I don't think that would be possible but then again it might....... :-?
HAHA. i would hang him by his balls if he did that. :lol:
ironi
Postby ironi » Wed Apr 06, 2005 5:54 pm
bassthrive wrote:bump stop wasnt cut?
bump stops were cut. i made sure they were cut in the right place according to the install manual.
ironi
Postby ironi » Thu Apr 07, 2005 7:33 am
Your car does NOT sit on the BUMPSTOPS....
THEY DO NOT CHANGE THE HEIGHT!!!!!! SPRINGS DO!!!!!
i know. any ideas, milt?
ironi
Postby arch.HI » Thu Apr 07, 2005 9:26 am
Is it possible that the arrow on the strut mount is pointing the wrong way? The rear can be put in only one way but the front is directional. I doubt it's that though.
2000 Camry LE V6
TRD Supercharged
arch.HI
