SolaraGuy.com • View topic - New 18's rubbing Tires 235
Postby V8killa » Wed Apr 06, 2005 8:52 am
Just installed my new rims and the back rubs when I go over dips and turn into driveways. What can I do to stop it from rubbing, I have seen cars lower than mine in the rear and they don't have these problems...
Any suggestions guys??????????
95 auto Corolla w/turbocharged 20V Motor
97 Camrey XLE V6----GONE I Miss her so much
99 Solara SLE V6 UNDER CONSTRUCTION
V8killa
Postby krawzyazn » Wed Apr 06, 2005 8:57 am
what size is that??? 18X what?
Postby V8killa » Wed Apr 06, 2005 9:23 am
Sorry about that 18x7.5 / Tires are 235/40//18
V8killa
Postby cdeez » Wed Apr 06, 2005 9:35 am
roll your fenders...and w/7.5 i didn't think it was possible rub unless the offset is off by a lot.
last standing...
Socalara...
cdeez
Postby swimshady906 » Wed Apr 06, 2005 9:47 am
You could just wait untill your tire gets worn out in the back .... :roll: ... rolling the fender is best otherwise this problem will just go away as you drive.
02' S2000 Silverstone
swimshady906
Postby cdssolara » Wed Apr 06, 2005 3:06 pm
Mine rubbed with 225's on a 7 1/2" wide rim in the same situations. I had the rear fenders rolled and everything has been fine ever since.
cdssolara
Postby WTF?? » Wed Apr 06, 2005 4:39 pm
What was your offset???
Rolling the rear fenders has been one of the recommended solutions and it works
it should run you no more than $40 each fender and thats STEEP
Retired... its been fun Image
WTF??
Postby cdssolara » Thu Apr 07, 2005 11:30 am
My offset is +45. If it was 40, or even 42, I probably wouldn't have had the rubbing. I only had it when I had a lot of weight in the back, or I was driving very aggressively on back roads. The fender lips only had to be rolled slightly, and everything has been fine ever since.
WTF?? wrote:What was your offset???
cdssolara
