SolaraGuy.com • View topic - Grille work..
Grille work..
Grille work..
Postby Grazi07 » Mon May 02, 2005 1:42 pm
I've started using a Dremel tool to strip the chrome off my grille, and its leaving some rough edges. Anyone have any advice, other than finer grit sandpaper, to smooth it out?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby cdeez » Mon May 02, 2005 1:58 pm
i think sand paper is the only way bro...you should have tried paint stripper, i bet that would have taken all that chrome paint off.
last standing...
Socalara...
cdeez
Postby udonoogen » Mon May 02, 2005 2:39 pm
someone mentioned brake fluid would strip off the chrome
1999 V6 SLE, Diamond White Pearl
udonoogen
Postby Jai_Jai_Binks » Mon May 02, 2005 2:55 pm
This is the easiest process, i think:
1. remove grill from teh car
2. Spray some paint thinner.
3. take it to the thoes selfserve/coin operated carwashes
4. Spray the nozzle of the pressure washer close to the chrome part..and the chrome starts chipping off....
One reason i say off the car, is cus you don't want your paint to be dicolored!
Postby 1st Gen Sol » Mon May 02, 2005 3:06 pm
Brake Fluid works good on the chrome but you gotta make sure you don't leave it on the grill too long or it'll get fawked up.
I used the Dremel to sand down the little plastic pieces left from cutting the actual cent out to get it flush and somewhat smooth.
Good Luck on your project.......I'm yet to finish mine...... :o
1st Gen Sol
Stock Sleeper
Stock Sleeper
