SolaraGuy.com • View topic - TRD raditor cap
TRD raditor cap
TRD raditor cap
Postby chinaxb0y » Thu May 05, 2005 6:43 pm
does anyone here have a raditor cap for their solara ? if so what psi is it and would u know if its a deep neck or a shallow neck. i had bought one and it don't fit and stupid dealer doesn't know.
chinaxb0y
Re: TRD raditor cap
Postby Paladin06Greg » Fri May 06, 2005 3:12 am
I have one and it's marked as 1.3. I wouls say it's shallow neck for sure. See the link below for more details.
http://www.toyotaparts4u.com/e_catalog/
chinaxb0y wrote:does anyone here have a raditor cap for their solara ? if so what psi is it and would u know if its a deep neck or a shallow neck. i had bought one and it don't fit and stupid dealer doesn't know.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Fri May 06, 2005 6:42 am
Yeah i got one.
It just that the kg's are different.
TRD radiator cap has different boilin' point for coolant to pass from the reservior to the engine. [ i think that right]
Postby SpeedSTARs » Sat May 07, 2005 12:43 am
I have one of those. There are two caps offered for the Solara. One for the V-6 and the other is used on the I-4... Have any of you guys seen the Anti-Freeze seep out of the reservior cap opening around the lip??? You can see the coolant build-up along the cap. Is this normal???
Thanks in advance guys,
-G :)
SpeedSTARs
Postby Paladin06Greg » Sat May 07, 2005 4:45 am
I have seen a little around the reservior but not around TRD cap.
SpeedSTARs wrote:I have one of those. There are two caps offered for the Solara. One for the V-6 and the other is used on the I-4... Have any of you guys seen the Anti-Freeze seep out of the reservior cap opening around the lip??? You can see the coolant build-up along the cap. Is this normal???
-G :)
Last edited by Paladin06Greg on Sat May 07, 2005 10:42 am, edited 1 time in total.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby chinaxb0y » Sat May 07, 2005 10:22 am
is there a difference from the I-4 and the v6 ??? at the trd site it only shows for the v6 ...
chinaxb0y
Postby Paladin06Greg » Sat May 07, 2005 10:43 am
There may be a difference in system pressure. Get the one for your engine and you can not go wrong!!
chinaxb0y wrote:is there a difference from the I-4 and the v6 ??? at the trd site it only shows for the v6 ...
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SpeedSTARs » Sat May 07, 2005 6:36 pm
Paladin06Greg wrote:I have seen a little around the reservior but not around TRD cap.
-G :)
Hello Greg,
Its the reservior plastic cap area. I think i might have found a solution to this reoccuring issue. To solve this, i've applied some clear silicone chalk on the plastic's outer ring (the area where the cap pops into the bottle) to help seat the reservior cap to the odd shaped bottle. I believe the coolant is seeping through because of the poor blow mold injection process Toyota uses. Hopefully this helps everyone out with this seeping problem.
-G :turn-l: :turn-l: D guys
SpeedSTARs
Postby SleeperSolara » Mon May 09, 2005 7:36 am
SpeedSTARs wrote:Hello Greg,
All i did was get my dad's 98 Camry V6 reservior.
And no leaks.
