SolaraGuy.com • View topic - Matrix led's in the dash??
Postby xavier » Fri May 06, 2005 9:48 am
I searched and saw the lighting guide but I didnt see if anyone has tried those matrix 194's for the guage cluster? Has anyone tried em? Do they fit?
xavier
Postby RichD978 » Fri May 06, 2005 10:10 am
they do but the guages wont be completely lit
RichD978
Postby xavier » Fri May 06, 2005 11:28 am
even with the matrix ones. The matrix ones have one oval opaque in the middle and 4 other led's facing the sides so its 270 degrees of light supposedly
xavier
Postby RichD978 » Fri May 06, 2005 11:53 am
i would ask Jon
RichD978
Postby xavier » Fri May 06, 2005 11:53 am
whos Jon?
xavier
Postby RichD978 » Fri May 06, 2005 11:55 am
the one who made the tutorial for interior/exterior lighting
RichD978
Postby bassthrive » Fri May 06, 2005 2:26 pm
wide angle, matrix, beam - all LED's will give you bright/dark spots on your gauges. stick with colored incandescent 194's.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jon11582 » Fri May 06, 2005 5:01 pm
bassthrive wrote:wide angle, matrix, beam - all LED's will give you bright/dark spots on your gauges. stick with colored incandescent 194's.
Xavier, Got your PM. I think what Bassthrive says is true, but your welcome to try.
The matrix LED still has hotspots, because its still focused on 5 spots, even though it illuminates alot better. Its no where as drastic as as the other LEDs, but its still there. I think it would be especially noticable in the dash, since theres a small area between the LED and the surfaces they illuminate (i.e. a matrix LED for the trunk wouldnt be so bad since the focused light diffuses over a distance)
Im pretty sure they will fit, since theres still good vertical clearance, but for red, the regular red bulbs are just as good as the LEDs for color, so I would stick with those, and not worry about hotspots or spending more on Matrix LEDs.
2000 Black Solara SE
Jon11582
Postby xavier » Fri May 06, 2005 5:43 pm
ok guys....I think thats what I will do then...I'll go with the red 194's incandescents. I'm repainting mine until I get some
xavier
