SolaraGuy.com • View topic - exhaust time
exhaust time
exhaust time
Postby 209solara » Thu May 12, 2005 11:22 am
so ive had my s/c for about 7500 miles now and id say its broken in. since i had the solara i planned on the full jpp header exhaust combo. should i do this or would the apexi with a custom y pipe work as well. if i do just the exhaust first can the jpp headers still match up. and how much will the exhaust "open up" the power. auto s/c wih cai
209solara
Postby Fletch » Thu May 12, 2005 11:43 am
The biggest bottleneck is in the y-pipe. If you have the cash go for full JPP and forget about it.
2006 Legacy GT spec.B
Fletch
Postby 209solara » Thu May 12, 2005 11:55 am
im looking for best performance gains. dont want crazy loud exhaust or show type muffler, its all about getting from point a to point b faster.
209solara
Postby SpeedSTARs » Thu May 12, 2005 12:14 pm
I have the full JP exhaust system, and I must say, they make a big difference if you have the blower to go with it. If your worried about too much noise, then thats the draw back. As with all performance mods, they drink more fuel and produce more noise (due to a more efficient running motor to free up that restricted power). This system is no buzzer/ gazoo. It sound more very throaty compared to the rear section TRD cat-back exhaust... Hey guys correct me if I'm wrong. I wish you luck on however way you go. :wink:
-G :turn-l: :turn-l: D guys
SpeedSTARs
Postby StockSolara » Thu May 12, 2005 12:33 pm
Go for JPP if you got the $$$$ but if not then do custom y-pipe and either a custom cat-back or like you said jus get the A'pexi or something else. It will be a lot more effective if you went for the full JPP because the headers will become less reistrictive and a better flowing y-pipe with a 3 inch cat-back exhaust. Your S/C will love it
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby 209solara » Thu May 12, 2005 1:06 pm
so correct me if im wrong but will the car still be smoggable if i get the jpp setup? what will i need to look for i.e. pluging o2 sensor holes
209solara
Postby Mole » Thu May 12, 2005 3:40 pm
^nope.
well the car will still be smoggable. but it will not pass.
Postby StockSolara » Fri May 13, 2005 1:07 am
You will need the switch out the JPP high flo CAT with a OBD II CAT
2000 Lexus GS400
StockSolara
Postby Astro » Fri May 13, 2005 3:17 pm
StockSolara wrote:You will need the switch out the JPP high flo CAT with a OBD II CAT
Wouldn't it still fail smog after that?
Postby SpeedSTARs » Fri May 13, 2005 8:11 pm
Hello guy's,
I thought the TRD blower was not Smoggable??? Let along the JP exhaust system. I'm just fortunate to be in a state that doesn't require such strict laws. :(
SpeedSTARs
Postby 209solara » Fri May 13, 2005 9:22 pm
you can pass smog with the s/c it has a carb sticker.
209solara
Postby SpeedSTARs » Fri May 13, 2005 9:28 pm
209solara wrote:you can pass smog with the s/c it has a carb sticker.
Ok... Than clears things up a bit. Thanks.:D
-G
SpeedSTARs
