SolaraGuy.com • View topic - Front 18's Rubbing
Front 18's Rubbing
Front 18's Rubbing
Postby viper1400 » Mon May 16, 2005 9:45 am
Hey guys, I've been running 18's for about a year now, and I have always had a little bit of rubbing on my front tires...sometimes in the back when there is a full load.
The wheels I have are 18x8's with a 38mm offset (no spacers)...at least thats what i was told...and i am running 225/35 tires. In the front, I am rubbing against that little piece on the bottom of the fender that sticks out so that it can hold the plastic wheel well thing in place...i was under the impression that the 38mm offset would be fine for the car, but it seems as if the wheels are sticking too far out???
Any solutions or input would be much appreciated...
"I'll get it when i have the money..."
viper1400
Postby StockSolara » Mon May 16, 2005 12:08 pm
roll your fender
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Mole » Mon May 16, 2005 12:59 pm
you cant really roll the front.
just bend the area that's hitting. becareful though. its delicate.
Postby rnsmelody » Mon May 16, 2005 1:09 pm
what you can do, is use a dremo and shave it down a bit..
rnsmelody
Postby TRD MCV20L » Mon May 16, 2005 4:44 pm
How bad is it rubbing?
TRD MCV20L
Postby lazyboyz69 » Mon May 16, 2005 4:48 pm
get new smaller tires.... 215/35/18 thats what i did... no more rubb....
lazyboyz69
Postby viper1400 » Mon May 16, 2005 5:36 pm
will 215's fit on 18x8?
viper1400
Postby viper1400 » Mon May 16, 2005 5:37 pm
it's not rubbing too bad, just when i take a sharp turn while accelerating (low speeds) or when i hit a bump on the road...
viper1400
Postby Mole » Mon May 16, 2005 10:07 pm
viper1400 wrote:will 215's fit on 18x8?
it will look a tad awkward. however if you get a tire with a wider foot print, it will look as if it were a 225.
Postby CASTRO » Mon May 16, 2005 10:20 pm
mine didnt rub on the fender that much, but if you are slammed or your diameter is huge, be careful with the ABS wire. that stupid thing rubbed against my tire for being too low while doing some spirited trail driving and it snapped. I relocated it so that its not directly above the tire.
CASTRO
Postby viper1400 » Tue May 17, 2005 4:32 am
is there any way that i can move the wheels "more inside" the wheelwell?
viper1400
Postby StockSolara » Tue May 17, 2005 6:03 am
viper1400 wrote:is there any way that i can move the wheels "more inside" the wheelwell?
Get a higher offset. . . I have 18 X 7.5 with 45 offset wrapped with 235/45/18 and I don't rub at all.
2000 Lexus GS400
StockSolara
Postby Mole » Tue May 17, 2005 11:49 am
you cant really raise your offset once you have wheels.
Postby viper1400 » Wed May 18, 2005 12:39 am
Hey, i was just thinking, I have KYB struts...do you think this has anything to do with it? Could it be an alignment? Is there any way to fix this with the wheels I currently have? If so, what are my options?? I know I keep on asking questions, but if anyone has maybe a thorough answer, I would really appreciate it...
viper1400
