SolaraGuy.com • View topic - New Clutch from SPEC
Postby shidosha01 » Tue May 17, 2005 7:17 pm
Well...
"tabasco" finally has a new and stronger clutch. It now sports SPEC Stage III F with SPEC lightened flywheel. I'm in the process of breaking in for 500 miles and then I'll test it out at the track. Apparantly the SPEC Stage III couldn't hold the amount of power "tabasco" was putting to the wheels. About 20 passes at MIR and regular street driving. :( This new Stage III F was special order from SPEC which allows smooth engagement but able to withstand abuse and HUGE amounts of power. I'll keep you guys posted on this new clutch and lightened flywheel works out.
I'm feeling very good about this new clutch because I pulled that 13.38 with the old one towards the end of the racing season. :wink: C'mon 12s. :D
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
nice
Postby trd4life » Tue May 17, 2005 7:32 pm
Look forward to seeing new track times :D
Re: nice
Postby shidosha01 » Tue May 17, 2005 7:44 pm
trd4life wrote:Look forward to seeing new track times :D
With the mods you're getting done. I'm sure you're speaking for yourself. :wink: j/k
shidosha01
Postby lazyboyz69 » Tue May 17, 2005 8:01 pm
dang you 13 second solaras... one day i'll be there.... .6 seconds away from 13's....
lazyboyz69
Postby Fletch » Wed May 18, 2005 4:23 am
When I bought the stage III, it I thought it said it could hold 492 lb*ft. Still not enough holding power???
2006 Legacy GT spec.B
Fletch
Postby michaels artic frost » Wed May 18, 2005 4:30 am
Congrats on your new upgrade Rizal and good luck to ya on hittin' the 12s.
Hard work and persistence = :D
-M 8)
Updated 06/01/12: Michael T's
Postby shidosha01 » Wed May 18, 2005 10:31 am
Fletch wrote:When I bought the stage III, it I thought it said it could hold 492 lb*ft. Still not enough holding power???
Apparently not. I was surprised how the Stage III wore out quickly. You've got to also consider the weight of our cars too. We'll see how the new SPEC Stage III F holds up.
shidosha01
