SolaraGuy.com • View topic - Is this normal???? **56K - just dont**
Postby that1mexguy » Thu May 19, 2005 6:57 pm
OK well as you guys know I installed my SC a few weeks ago and I've been noticing that my whole engine is dirty as heck with some sort of black power ... is this normal??? (see pics below)
This is just a normal pic of the engine, right in front of the SC ... looks normal, right ...wroooong
This is a close up .... is it normal???
And as you can see, it's all over!!! :-?
that1mexguy
Postby geminimouse » Thu May 19, 2005 7:17 pm
i showed the pic to my brother
he says it might be belt shavings...make sure nothing is touching the belts and check the tensioner..
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby SpeedSTARs » Thu May 19, 2005 7:20 pm
Hey bro,
I think your belt is grinding against itself where you have the dynamic pretensioner. :o just from what i see in the pics. Do you have the proper belt diameter? Also, just from observation, the belt seems to be thin. Check to see if your running a 86.7" or so belt diameter. That's all i can think of. Good luck man. :angel:
-G
SpeedSTARs
Postby wiz2 » Thu May 19, 2005 7:30 pm
Make sure its not rubbing. Open hood run the motor have someone rev it to make sure the tensioner is moving. I had a little powder after I intiall installed mine.
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby Jackass-Jeff » Thu May 19, 2005 7:31 pm
take the drive belt off, check all pulleys to make sure they are smooth. then make sure all bolts were properly secured and check the routing of the belt
snapped belt = ouch.
1GR-FE ftw!
Jackass-Jeff
Postby Hsakuragi » Thu May 19, 2005 7:40 pm
what the heck is that thing in front of the between the belt and steering fluid reservior?
Hsakuragi
Postby SpeedSTARs » Thu May 19, 2005 7:47 pm
Hsakuragi wrote:what the heck is that thing in front of the between the belt and steering fluid reservior?
I believe that is his alarm siren horn.
SpeedSTARs
Postby that1mexguy » Thu May 19, 2005 7:50 pm
yup, that's the alarm thingie.... aight, i'm calling the shop where i got it installed tomorrow and have them check it out .... i didnt think it was normal so we shall see... thanks guys
:drinking:
that1mexguy
Postby SpeedSTARs » Thu May 19, 2005 7:53 pm
that1mexguy wrote:yup, that's the alarm thingie.... aight, i'm calling the shop where i got it installed tomorrow and have them check it out .... i didnt think it was normal so we shall see... thanks guys
:drinking:
Your most certainly welcome Bro.
:drinking:
-G
SpeedSTARs
belt rubbing
Postby trd4life » Thu May 19, 2005 8:06 pm
Dont call the shop your all set man. Thats just dust form the belt since its brand new. It happened to me as well as three other guys i know with the same setup. Wait a couple weeks it will stop then pressure wash the engine and you'll be good to go.
Postby Mole » Fri May 20, 2005 6:38 am
that much dust does not happen to me.
Postby Mandarinsolara » Sat May 21, 2005 9:39 am
HAHA that sux
Mandarinsolara
Postby SC V6 » Sat May 21, 2005 7:40 pm
Definitally Belt shavings... I get that and some metal shavings from the idler pulley hitting the actual setup... its normal
SC V6
Postby quikz » Sun May 22, 2005 8:15 pm
check the belt to see if rubbing on something, guys say that its normal, i guess so? pressure wash the engine it'll look like new.
01 blk SLE
quikz
