SolaraGuy.com • View topic - LED clear corners
LED clear corners
LED clear corners
Postby Dawgz » Tue May 24, 2005 7:32 am
has anyone done this yet? do you think it would turn out good? i just had the idea, like make the leds inside the housing, not as a bulb but set them up in rows....
Postby RichD978 » Tue May 24, 2005 8:30 am
try it and let us know
RichD978
Postby FLASH » Tue May 24, 2005 9:52 am
I thought about it...got as far as drilling holes in the lense for the LEDs...but I don't have the electrical know-how on how to do it.
It would be pretty neat, but I dont know what to do about the big hole where the bulb would usually be
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Turbosolara » Tue May 24, 2005 9:58 am
I have LED bulbs inside my front corner lenses. It is no as bright as regular bulb but it turns my signal light into hyperblinker
Postby Dawgz » Tue May 24, 2005 12:40 pm
Turbosolara wrote:I have LED bulbs inside my front corner lenses. It is no as bright as regular bulb but it turns my signal light into hyperblinker
yea because u need a resistor, the way u have it setup, ur car thinks the bulb is dead because the leds dont use that much power as the reguler 1156 bulb or watever bulb uses. so it thinks its dead, with not much resistance to it, i think the relay makes it bling faster. Im gonna add resisotrs to my led setup.
FLASH wrote:I thought about it...got as far as drilling holes in the lense for the LEDs...but I don't have the electrical know-how on how to do it.
well, the piece is gonna plugged in my the stock socket, but im gonna add a Mirror finish to the end of it so itll look flush with the whole setup, ill surely take pics, and thanx to jon, i have a clear corner to work on.... :drinking:
Postby 1st Gen Sol » Tue May 24, 2005 1:00 pm
I've thought about it but as "Flash" said.....I also don't have the electrical know how....to do this.
Would be interesting to see....take some pics when you complete your project.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Dawgz » Tue May 24, 2005 2:14 pm
yea, ill take pics of the proccess so i dont forget when i make a SET, cause im gonna be working on one piece. and if it works out well, then ill buy a set offa ebay and then make it for my car.
Postby thealkimo » Tue May 24, 2005 3:17 pm
haha too much work!
but lets see how they turn out...
thealkimo
Postby Fresco Bob » Tue May 24, 2005 7:04 pm
so are you talking about somthing like having them in a row like this?
Fresco Bob
Postby bassthrive » Tue May 24, 2005 7:11 pm
those led's look like crap.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby 1st Gen Sol » Tue May 24, 2005 7:42 pm
looks like the dude cut a strip of Burberry Fabric and tried to line it up straight inside the headlight but failed miserably..........or from hitting all dem bumps and potholes.....ended up crooked
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby RichD978 » Tue May 24, 2005 7:52 pm
thats one nice cam though.. minus the leds and the ugly mirrors
RichD978
Postby Dawgz » Tue May 24, 2005 8:21 pm
Fresco Bob wrote:so are you talking about somthing like having them in a row like this?
not really, not even the same concept either, he has the strip leds, im gettn about 300 to work with, 300 single ones, i think per corner i should have used about 30-40 leds that total would draw half of wat the current bulb requires. and mine are not gonna be in a row like that, if u check ur corners the mirror near the bulb is in a circulur way. im gonna follow that and drill holes within each little triangle and put a led in each, that setup there will be about 20 leds, then there will be another 5 in the front and another 5 more leds where the orange reflector used to be in the stock corner. im not gonna add more places but i might take out some. i think it should look REALLY hot. but thats my opinion. :D
Postby SpeedSTARs » Tue May 24, 2005 9:17 pm
Like the fact the guy put some effort into fixing the head Lamps; However, the dude is a 1999 Honda Accord freak. :lol: :lol:
Do you guys see the similarities??? :lol: :lol:
SpeedSTARs
Users browsing this forum: No registered users and 119 guests
