SolaraGuy.com • View topic - New tranny cooler question.
Postby SleeperSolara » Sun May 29, 2005 7:43 pm
This is a question for the people who have done an external add-on tranny cooler.
Hey i had just got my new tranny cooler, and spliced the right tubin' for my tranny cooler.
Did i do it right, or is it the left one.
Can you guys look at yours anc tell me which one of the tubes you spliced the tubin' for the cooler.
Postby Hsakuragi » Sun May 29, 2005 8:12 pm
right...
Hsakuragi
Postby Mandarinsolara » Mon May 30, 2005 11:25 am
if its got fluids in it and it makes a circuit through the transmission, then it should be fine. make sure you put in extra fluid.
Mandarinsolara
Postby SleeperSolara » Mon May 30, 2005 11:39 am
Yeah i did, sort of.
How much?? i got 5 quarts in there.
"Hsakuragi" facin' the engine right??
Postby jazzlara » Mon May 30, 2005 12:16 pm
facing the engine, then i believe the right tube is the hot.
you can either bypass the radiator all together or combine the new tranny cooler along with the radiator.
jazzlara
Postby SleeperSolara » Mon May 30, 2005 2:19 pm
jazzlara wrote:facing the engine, then i believe the right tube is the hot.
Really the right is the hot side.
I am usin' it injunction wit my radiator.
Postby Mandarinsolara » Mon May 30, 2005 2:53 pm
to get the fluids right, you should uninstall the system and fill the removed pieces (hoses and cooler) with something (i dont imagine water would be safe, trans fluid might be too expensive i dont know.) then pour it into a container and measure it. thats how much you should add to the factory amount. i do know that getting the fluid level wrong can cause goofy shifting, i doubt it would mess it up too much though.
if it shifts too quickly, then you have too much fluid. (let the motor 100% warm up before making this decision)
if the shifts drag out into a high rpm range, try adding a good little bit.
if im way way off then please someone say somethin.
Mandarinsolara
Postby SleeperSolara » Mon May 30, 2005 3:21 pm
I added 5 quarts, and too lazy on tryin' to check how much i needed, i think i have enough in the tranny.
Was figurin' out which is hot and cold side for OEM tranny cooler, facin' the engine though.
I put my "L" tubin' on the right.
One person side right tube is hot, other say cold.
Was askin' people who've done it which one did they tap into.
Users browsing this forum: No registered users and 121 guests
