SolaraGuy.com • View topic - eaisest way to cut e-brake handle
Postby Grnarowana » Wed Jun 08, 2005 6:07 pm
What is the eaisest way to cut the e-brake handle plastic without fuckign anything up?
Grnarowana
Postby Yanks0114 » Wed Jun 08, 2005 6:14 pm
why do you want to cut the ebrake handle? and how much are you trying to cut?
Postby Grnarowana » Wed Jun 08, 2005 6:24 pm
to hop in a wooden e-brake handle, im tryign to wood trim the bajesus out of the car's interior
Grnarowana
Postby Paladin06Greg » Wed Jun 08, 2005 6:28 pm
Why don't you just get a wood trim cover?
Grnarowana wrote:to hop in a wooden e-brake handle, im tryign to wood trim the bajesus out of the car's interior
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Grnarowana » Wed Jun 08, 2005 6:35 pm
everythign is wood trim except for the e-brake and shift knob...wood trim cover? you mean a plastic cover that fits over the e-brake handle w/o cutting it?
Grnarowana
Postby Yanks0114 » Wed Jun 08, 2005 9:42 pm
Grnarowana wrote:everythign is wood trim except for the e-brake and shift knob...wood trim cover? you mean a plastic cover that fits over the e-brake handle w/o cutting it?
Yes, i'm pretty sure thats what he meant. It would be a heck of a lot easier
Postby Rookie Solara » Thu Jun 09, 2005 11:27 am
I don't think I have seen 1 that will be direct slide in over the stock handle without removing the stock handle piece..........all those aftermarket E-brake handle (from ebay or speed shop) required you to remove your stock handle then slide the new one in and set it with a set-screw from the bottom......
I have never cut my e-brake and install those aftermarket handle, but I have seen those who did on HONDA or other japanese car....I think (again, I think, use your judgement and guess Solara is one of the same as those HONDA).......all you have to do is CUT the handle in the middle, and rip the stock piece out, then slide the aftermarket one in....
Again, it is point of no return, so if you decided to cut, see you can cut it from the SIDE, and LOWER is better.........just in case Solara E-brake handle is NOT as easy as Honda's you can GLUE it back and since it is from the side, and bottom, it won't be too visable....
I don't believe this mod is that bad............just a handle, not a timing belt change....
TRD Stage 3 and sway bar
Ground control Coilover kits
Koenig Tantrum 18x7.5
Apexi N1 exhaust
Apexi S-AFC air fuel controller
Rookie Solara
