SolaraGuy.com • View topic - 225-45-18 tire question
Postby kilade » Wed Jun 15, 2005 12:47 pm
I'm getting 18 x 7.5 wheels and wanted to know if 225/45/18s tires will fit and not rub. The car is not lowered but i'm planning to put some tein springs on in the near future. I know the recommendation is to use 225/40/18 but the 40 profile seems to skinny for me. I like tires with a little more meat, i had 40 profile before and did not like it. Anyone using 225-45-18s out there? any rubbing? any other suggesions?
thank you
kilade
Postby SmokeoUtRObert » Wed Jun 15, 2005 1:21 pm
it shouldn't rub....im thinkin about getting 45 for my next tires as well....
SmokeoUtRObert
Postby Rookie Solara » Thu Jun 16, 2005 6:36 am
I have 235/45-18 on my Solara with 3" drop (ground control)....rims are 18x7.5 with 38mm offset (I think)...no rub, so dont' worry if you are mounting anything narrower then my spec...(pics are with 19")
TRD Stage 3 and sway bar
Ground control Coilover kits
Koenig Tantrum 18x7.5
Apexi N1 exhaust
Apexi S-AFC air fuel controller
Rookie Solara
Postby Fletch » Thu Jun 16, 2005 6:49 am
Since 225/45 is not the most common size it may cost a little more for the tire. The question of whether it will rub or not also depends on the offset of the wheel; with a 45 offset you would probably be okay, a 35 offset and you may rub.
Another thing to consider when looking for a tire is the tread width, I think tire rack has that information now on their site. Find a 225/40 with a wide tread width and it will look good.
2006 Legacy GT spec.B
Fletch
Postby Van » Thu Jun 16, 2005 1:57 pm
I run 18x7.5 with 225/45/18 tires The offset is 42. It's just perfect. I think 225/45 is better than 225/40. And you still have lots of space to drop your car.
Van
Postby methyl mike » Fri Jun 17, 2005 10:13 am
Fletch wrote:Since 225/45 is not the most common size it may cost a little more for the tire. The question of whether it will rub or not also depends on the offset of the wheel; with a 45 offset you would probably be okay, a 35 offset and you may rub.
What about a 35 offset in back and 45 in front with a 245/40 tire set up? Or maybe 235/40 with a wide tread width?
methyl mike
Postby StockSolara » Fri Jun 17, 2005 7:15 pm
I have 18X7.5 with 45 offset on 235/45/18 and I don't rub at all
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby kilade » Sat Jun 18, 2005 10:30 pm
what kind of suspension set up do you have stocksolara? you got a nice tucked in look. i'm gonna get 18x7.5 & 45 offset with 225/45/18 because the 235 45 18 are just too expensive. thanks
kilade
Postby StockSolara » Sun Jun 19, 2005 2:26 am
kilade wrote:what kind of suspension set up do you have stocksolara? you got a nice tucked in look. i'm gonna get 18x7.5 & 45 offset with 225/45/18 because the 235 45 18 are just too expensive. thanks
I have Eibach w/ Tokico
2000 Lexus GS400
StockSolara
Postby Rookie Solara » Mon Jun 20, 2005 11:50 am
I just found out mine is 235/40-18 instead of 45 AR..........man, I really didn't spend too much time on my Solara anymore.
Apexi N1 exhaust
Rookie Solara
