SolaraGuy.com • View topic - small hole in the clear corner
Postby udonoogen » Tue Jul 05, 2005 5:27 pm
what is it for? theres a little L shaped rubber piece that extends the hole. should i seal it up with silicone?
udonoogen
Postby 1st Gen Sol » Tue Jul 05, 2005 6:01 pm
That L-shaped hole in the corner lamps are made to prevent your corners from fogging up and moisture & condensation build up.....don't seal them up.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby udonoogen » Tue Jul 05, 2005 6:30 pm
ah. i see. thank you!
udonoogen
Postby 1st Gen Sol » Tue Jul 05, 2005 6:36 pm
No prob........if you just got those clear corners, you might want to also add some extra silicone to the casing before installing them b/c some of them are known to fog up.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby bassthrive » Tue Jul 05, 2005 6:37 pm
just seal the edges where the plastic lens joins the rest of the corner.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Users browsing this forum: Google [Bot] and 48 guests
