SolaraGuy.com • View topic - knock senor blew...reset ecu....gone....
Postby lazyboyz69 » Tue Jul 26, 2005 11:32 am
well i was driving.... check engine light went on....car felt really slugish ... checked the code it was the knock senor..... i bought some fuel addictive and poured full tank of moble gas...went home reset ecu and the light hasn't come on yet..... should i replace the knock senor or just wait...
lazyboyz69
Postby StockSolara » Tue Jul 26, 2005 11:39 am
If it has blown you should replace it
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby thakidd » Tue Jul 26, 2005 12:17 pm
once its goes its gone,it will stay off for a few and then it will just get worse.........
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby SC V6 » Tue Jul 26, 2005 12:32 pm
yeah.. once blown.. it will never be the same.. it will eventually do it again
SC V6
Postby thakidd » Tue Jul 26, 2005 1:15 pm
just curious which sensor blew bank 1 or bank 2...........
14.3@96 60ft 2.173
thakidd
Postby Hsakuragi » Tue Jul 26, 2005 1:53 pm
can you provide more details on "driving"?
Hsakuragi
Postby Astro » Tue Jul 26, 2005 3:43 pm
Man, that sucks. Rizal just mentioned to me today about a GM modified knock sensor if I want to raise boost. I'd hit him up for more info...
Postby lazyboyz69 » Tue Jul 26, 2005 5:58 pm
i blew bank one..... with the gm modified knock senor how much is it... is there much modification?
how much is the toyota knock senor?
lazyboyz69
Postby thakidd » Tue Jul 26, 2005 6:30 pm
no 1 knows if the gm sensor will fit i talked to jim about this sensors.i was the 1 who found it and alot of people said they would try it but i don't think any has i belive trd4life is the only 1 but his engine is still at stoid racing.
http://www.twosrus.com/new/Lower_Frames ... sknock.htm
14.3@96 60ft 2.173
thakidd
Postby Paladin06Greg » Tue Jul 26, 2005 6:37 pm
8) "i was the 1 who found it and alot of people said they would try it but i don't think any has i belive trd4life is the only 1 but his engine is still at stoid racing."
Not true.. 8)
thakidd wrote:no 1 knows if the gm sensor will fit i talked to jim about this sensors.i was the 1 who found it and alot of people said they would try it but i don't think any has i belive trd4life is the only 1 but his engine is still at stoid racing.
8) 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby shidosha01 » Tue Jul 26, 2005 8:40 pm
Astro wrote:Man, that sucks. Rizal just mentioned to me today about a GM modified knock sensor if I want to raise boost. I'd hit him up for more info...
Umm...
Its gonna take more work than just a knock sensor upgrade to run higher boost safely. Just check out Gabe's car. It might have worked out for him.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby lazyboyz69 » Tue Jul 26, 2005 9:16 pm
is it safe to drive around with a blown knock sensor?
lazyboyz69
Postby Hsakuragi » Tue Jul 26, 2005 11:48 pm
so lazyboy, were u just driving normally?
i'm asking because i'm wondering does it blew whenever it feels like it or you are puttting it to the limit in order to blew it..
it should be save to drive around, but ur will not have any power...
Hsakuragi
Postby lazyboyz69 » Wed Jul 27, 2005 12:11 am
i was just driving around... but the day before that i was driving really fast with very low gas....
lazyboyz69
