SolaraGuy.com • View topic - Tein SS Damper/Height Settings
Postby TheTamago » Tue Aug 02, 2005 2:24 am
http://www.solaraguy.org/viewtopic.php?t=13341
In regards to my project beginnings from the suspension work first to the wheels then the engine bay. Anyone with Tein SS coilovers. Can you please tell me your suitable setitngs for daily driving and maybe a good street setup for handling corners? And perhaps track settings as well. I might be crazy to ever do such a thing with my car to bring it for a track run.
Since its an all in one solution :lol: Thanks in advance! 8)
PS: I have mudguards on so I don't wanna be too crazy to lower the car to much that I hear a crack when I tackle a speed bump :roll:
TheTamago
Postby arch.HI » Tue Aug 02, 2005 12:01 pm
I'm on Tein SS. You want the settings... I really just adjusted them till I found a sweet spot. I think the dampening is set one notch stiffer than minimum. The front ride height is pretty low while the rear is still pretty high.
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby SpeedSTARs » Tue Aug 02, 2005 12:20 pm
:D SUP Bro.
I have mine set for 10 click (standard setting) in the front and 12 clicks in the rear. The Tein SS is stiffer than the TRD struts/ Eibach setup I use to have; however it rides much better as far as dampening goes. I dropped it 65mm mostly due to all the pot holes around here. :D
These setting worked for me as a daily driver. Hope it works out for you Bro. :wink: :angel:
SpeedSTARs
Postby SC V6 » Tue Aug 02, 2005 12:38 pm
where did u guys get your teins from? Any good prices.. im lookin into getting these
SC V6
Postby arch.HI » Tue Aug 02, 2005 12:44 pm
I got mine from RJ@UPFD $1151 shipped
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby Jackass-Jeff » Tue Aug 02, 2005 1:14 pm
I'm probably the first guy to have them installed... besides the test guy.
It took some time, but my front is set at 4 (4 clicks from maximum stiffness) and rear is set around 7 clicks from max with a TRD RSB on TRACK setting.
My car now oversteers into corners while understeering out... only because of the lame settings... but my car is starting to creek like a bitch! Too bad it's still fake oversteering =P
My height is currently below the suggested... I'm riding a 225/40R18 and the front has no gap when the car is loaded. It's about 1/2 a finger unloaded. The rear has a 1 finger gap unloaded. 1/2 finger if loaded w/ passengers. It bounces a lot more... since the spring isn't designed for it.
1GR-FE ftw!
Jackass-Jeff
Postby importtuner2oo4 » Fri Aug 05, 2005 9:53 pm
is that creeking due to the RSB or the Teins?
importtuner2oo4
Postby SpeedSTARs » Fri Aug 05, 2005 11:24 pm
importtuner2oo4 wrote:is that creeking due to the RSB or the Teins?
:P IMHO, The creeking is most likely coming from the rear sway-bar. The Marine grease applied to the bushings should solve this problem. Also check to see if the nuts and bolts are nice and tight. :wink: :D
SpeedSTARs
Postby Jackass-Jeff » Sat Aug 06, 2005 8:06 am
it probably is... lol
I'm gonna set it to street setting when i have time... track is quite harsh w/ the dampening setting I'm on in the rear. If the handling dies, then I'll switch back.
1GR-FE ftw!
Jackass-Jeff
