SolaraGuy.com • View topic - White face gauges.........
Postby SleeperSolara » Sun Aug 28, 2005 5:51 pm
Well i have just bought some Ebay white face gauges from NexTech.
Well i was tryin' to wire up the gauges, but the only problem is that, i would wire the switch up.
All that came wit he gauges was of course the gauges, and a switch and an inverter.
Well on the the inverter there are some wires that come out; 1 for the gauges to plug in; the second are 2 wires 1 black and 1 red of course that is the power and neg wires.
Then is a wire that plugs to the switch they gave me.
Well i really don't want to use their switch that they gave me.
I was to use that one wire taht plugs into the switch they gave me to my gauges when i turn them on.
The switch i'm talkin' is about is the 1 that turns on your stock gauge lights.
Well i want to wire my new white face gauges to the switch that turns on the "taillights".
I found out which wires it is to turn on the "taillights" and the instrument gauges.
The wires to turn on the instrutment panel is "14 & 16".
Can someone help me.
Thanks.
Postby DatSRBoi » Sun Aug 28, 2005 6:03 pm
Confused like a mofo.... I got lost after the first sentence.
Postby SC V6 » Sun Aug 28, 2005 7:05 pm
what I did w\ my gauges was just hooked the new gauges up indepentally from the origional knob... I just hooked the power up to a wire similer to the ignition wire so that the gauges were only on when the headlights were on... then I just had 2 toggle switches to dim the gauges... I dunno why you would want to hook them up to a switch for when the taillights went on..
further explaination might help also
SC V6
Re: White face gauges.........
Postby Jon11582 » Sun Aug 28, 2005 9:13 pm
SleeperSolara wrote:Well i have just bought some Ebay white face gauges from NexTech.
Thanks.
Tail lights like when you brake? Or tail lights when you have youar parking lights or headlights on?
If your talking about that, then hooking the red wire to the green with silver stripe wire does that exactly. Just leave the switch there, but attach it inside the dash. The gauges will turn on when your "taillights" are on...since when your taillights are on, your regular guages are also on. Its the same wire.
2000 Black Solara SE
Jon11582
Postby SleeperSolara » Mon Aug 29, 2005 7:05 am
Yeah i meant the instrument panel.
The wires to that are green wit silver stripe i think and the other is black wit white stripe.
So i would just plug in the red power wire from the gauges to the green one and the black to the black one.
But it don't work that way i think.
When i have a 9 volt plugged to the gauges you have another wire wit prongs on it that plug to the switch they gave me.
Sorry for the confusion, pops was naggin' me.
Postby Jon11582 » Mon Aug 29, 2005 11:10 am
SleeperSolara wrote:Yeah i meant the instrument panel.
Black should get grounded to the bolt behind the cluster.
I'm confused at this point too. 9V? so you have another powersource for the gauges?
Jon11582
Postby SleeperSolara » Mon Aug 29, 2005 12:27 pm
No i was usin' a 9 volt battery to supply the power to the gauges.
How would i wire the gauges wit out usin' the switch they gave me.
Remember that there is a wire that plugs into the switch they gave me.
I know to use the red wire and black wire to power and ground.
Can't i wire it to the turn on wheneva i switch on the gauges.
Postby Jon11582 » Mon Aug 29, 2005 1:18 pm
SleeperSolara wrote:No i was usin' a 9 volt battery to supply the power to the gauges.
Yea I think thats how everyone has it wired. I still dont get how the 9v falls into the equation.
Leave the switch in the circuit, just leave it on and put it inside the dash.
The green/silver wire already turns on with the dash. Youll never have to touch the switch it came with.
Jon11582
Postby krook » Mon Aug 29, 2005 4:14 pm
DatSRBoi wrote:Confused like a mofo.... I got lost after the first sentence.
no shit, man. give this man a vowel or two. also he's writing in verse.
eye
am
con
fyoozed
krook
Postby SleeperSolara » Tue Aug 30, 2005 1:55 pm
eye
am
con
fyoozed
Um, ok
Help on this is more helpful than junk on this thread.
Postby hanatsuki » Sun Sep 18, 2005 9:45 pm
okay, im trying to install the gauges in, how the heck do i do first step? i cant seem to get the thing out and im afraid of breaking it. Help! thanks in advance
What's hot, sexy and has a stick?
my solara v6
hanatsuki
Postby SleeperSolara » Mon Sep 19, 2005 7:37 am
What you need to know???
I just finished them.
They are off alittle.
Of course i got mine off Ebay.
PM later if you need help.
I think "that1mexguy" mad a tutorial. [check that out]
Postby krook » Mon Sep 19, 2005 8:35 pm
hanatsuki wrote:okay, im trying to install the gauges in, how the heck do i do first step? i cant seem to get the thing out and im afraid of breaking it. Help! thanks in advance
unscrew the 2 screws up top. get yourself a panel puller; this will make things much easier.
you can get them at sears, i think.... Image
krook
Postby SleeperSolara » Tue Sep 20, 2005 6:36 am
Don't got one nor will i eva probably buy one.
Postby SC V6 » Tue Sep 20, 2005 6:54 am
I've got one cause the local audio store left it in my car :drinking:
SC V6
