SolaraGuy.com • View topic - Slotted rotors wear and tear vs. drilled rotors
Postby Solorange » Mon Aug 29, 2005 8:54 pm
I was talking to a friend of mine the other day and I was telling him i wanted to buy brembo slotted rotors. He was telling me that if you get slotted rotors it wears the pads out quicker because the sharp edges in the slots cut into the pads. He was saying the drill rotors have countersinks in them so they dont cut into the pads. This seems to make sense. But I was wondering what your experiences are.
Postby StockSolara » Mon Aug 29, 2005 9:30 pm
He is right BUT the drilled ones are prone to crack easier than the others. . . Listed from most durable to least durable. . . blanks, slotted, drilled slotted, drilled
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Ford_Fixorrepairdaily » Mon Aug 29, 2005 9:44 pm
I have the ebc slotted dimpled rotors with the TRD brake pads. The rotors killed the TRD pads in about 13k miles.
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby Mole » Mon Aug 29, 2005 11:22 pm
TRD brake pads melt like butter regardless what rotors you use.
Postby RichD978 » Tue Aug 30, 2005 3:32 am
which pads do you recommend most mole? I thought trd would be the best to get, didn't realize they didn't last
RichD978
Postby SpeedSTARs » Tue Aug 30, 2005 9:42 pm
RichD978 wrote:which pads do you recommend most mole? I thought trd would be the best to get, didn't realize they didn't last
Mole's got that right.
I had a couple pairs of the TRD HP pads. They were kind of smushy when you got aggressive on them. It really did help when you were running slotted rotors. At the time I was running Power Slot rotors in all 4 corners. Those discs were like anchors and they chewed up those TRD pads like mozzarella cheese. They definitely weight more than the stock disc. :-?
IMHO, the Hawk HPS are my favorite. They are reasonably priced and they have a good service life with bite. And the best thing is that they have lower carbon content (meaning low brake dust). Instead of the black dust, you'll end up with grey dust. Oh yah, by the way, the Brembo's plain OEM replacements (rust like a MOFO cosmetic corrosion) are lighter than the Power Slot and stock rotors. Hope this info helps out Bro. :wink:
SpeedSTARs
Postby DaTwUnKrAziEpInOy » Tue Aug 30, 2005 10:32 pm
[quote="Mole"]TRD brake pads melt like butter regardless what rotors you use.[/quote]
You're Telling me.....TRD Pads isn't worth my 60 bucks
DaTwUnKrAziEpInOy
Postby Mole » Tue Aug 30, 2005 11:04 pm
i recommend EBC Green.
i've tried TRD, EBC Green , EBC Red and now on Porterfield.
Porterfield are bang for the buck, but if you want bite, go for EBC green.
EBC Red dusts like crazy.
And upgrade your lines.
Postby StockSolara » Tue Aug 30, 2005 11:13 pm
I have EBC Green and they give off A LOT of brake dust like I would clean my rims and in like 3-4 days they will have come back
2000 Lexus GS400
StockSolara
Postby Hsakuragi » Tue Aug 30, 2005 11:53 pm
litte off topic,
anyone tried this?
http://www.tirerack.com/brakes/brakes.j ... perfCode=A
Hsakuragi
Postby SpeedSTARs » Wed Aug 31, 2005 12:04 am
Hsakuragi wrote:litte off topic,
anyone tried this?
I had a pair of Satisfied pads before (not the ones you have listed).... However, the pads were like the TRD HP's. IMHO, they were a little spongy when they got too warm (super spirited driving conditions). 8)
SpeedSTARs
Postby SleeperSolara » Wed Aug 31, 2005 12:20 pm
So which rotors are best???
Slotted, or drilled, or both.
Postby Ford_Fixorrepairdaily » Wed Aug 31, 2005 12:27 pm
Really? I have the EBC red stuff with the EBC dimpled and the brake dust isnt bad as the TRD's.
Postby RichD978 » Wed Aug 31, 2005 1:44 pm
when you guys say upgrade brake lines... is that easy to do? like a newB would be able to DIY?
RichD978
Postby CASTRO » Wed Aug 31, 2005 2:01 pm
i did it myself and it really wasnt that hard. If you know how to change pads and bleed brakes, then youll know what to do with changing brake lines.
BTW, I race on the track and the blanks are your best bet for reliability. They never warp and you can resurface them for more track fun if they do warp. I've got the fatter 13inch supra brembo blanks and they feel great.
CASTRO
