SolaraGuy.com • View topic - Spark plugs and wires
Postby SleeperSolara » Wed Sep 07, 2005 7:32 am
Hey i was wonderin' if "Denso IK22 Sparkplugs" are good for my NA V6 auto Solara????
Would that be ok for my car.
Cause i'm thinkin' about gettin' some wires from "greg" and those spark plugs from "xtychx".
Will this work good wit my NA V6??
Postby Jon11582 » Wed Sep 07, 2005 7:37 am
I think a colder sparking plug (IK20 is stock, IK22 is colder spark) doesnt last as long as a normal sparking plug.
I'm not sure though, someone needs to confirm. I'd check Denso's site but its always been confusing to me.
2000 Black Solara SE
Jon11582
Postby StockSolara » Wed Sep 07, 2005 11:38 am
Since you're N/A. . . I think you should stick with the stock temperature
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SC V6 » Wed Sep 07, 2005 11:40 am
yeah.. colder plug is only needed for cars that could potentially ping.. ie supercharger/boost
SC V6
Postby SleeperSolara » Wed Sep 07, 2005 11:54 am
So which one should i buy.
Any examples would be helpful.
I'm new to the change os spark plugs.
Had an eye out for the wires already.
Postby SC V6 » Wed Sep 07, 2005 12:50 pm
I think the IK22's are the colder plugs for S|c.. while IK20's are regular?? someone know for sure?
SC V6
Postby Ian » Wed Sep 07, 2005 1:22 pm
correct.
Ian
Postby SleeperSolara » Wed Sep 07, 2005 1:33 pm
So i guess i should get: "IK20's"????
Postby SC V6 » Wed Sep 07, 2005 1:35 pm
u got it
SC V6
Postby SC V6 » Wed Sep 07, 2005 1:36 pm
u got it
SC V6
Postby SleeperSolara » Wed Sep 07, 2005 3:14 pm
Um, ok
Thanks.......
Postby bassthrive » Wed Sep 07, 2005 9:14 pm
IK20 is the iridium plug.
I read the blue and white sticker on the underside of the hood that clearly states "use platinum plugs with twin ground electrodes". When I did my 60k plug change I went with PK20 (PK20TR11). They are also made by denso, but are the multi-ground platinum plugs recommended by toyota.
If you have no future plans for running boost, use PK20.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jon11582 » Wed Sep 07, 2005 9:32 pm
Platinum lasts longer, Iridium should perform better.
They used to use platinum in Gen1 Solara and Gen4 Camry, but they use iridiums in the lexus ES, and I think the Gen2 Solaras (I need confirmation for that). They probably got the denso iridiums up to the point where the last as long as the platinums.
I'm using IK20s. Either way, I doubt you will notice any difference, so Platinum or Iridium will work.
Jon11582
Postby StockSolara » Thu Sep 08, 2005 12:30 am
Jon11582 wrote:Platinum lasts longer, Iridium should perform better.
Actually they said Iridiums are suppose to last 100K. . . haha after I did the sparkplug change. . . I really dont want to do it for another 100K
2000 Lexus GS400
StockSolara
Postby SleeperSolara » Thu Sep 08, 2005 9:49 am
Thanks for the info.
PK20 (PK20TR11) are the ones to use i guess.
Guess i will use them.
