SolaraGuy.com • View topic - Aftermarket Wheel Question???
Postby M_ABILLONES » Tue Sep 20, 2005 12:06 pm
Sup guys...new here in this forum...my first question pertains to the bolt pattern of the 1998-01 solara, is it a 5x100 or 5x114? Second, anyone here ever try to cram a 19x8.5 wheel on their Solara? Can it be done without any modification to the fenders? Third, where can I get the 7 pc trd body kit?
Mark
M_ABILLONES
Postby solaraslev67 » Tue Sep 20, 2005 12:11 pm
bolt pattern is 5 x 114.3 and im not sure if it will fit, but i needed to roll the fenders for my 18x8's with 225/40/18 tires, as far as the trd kit, there arent too many around anymore, havent seen a brand new one in a while but some people sell them painted and/or used u just gotta look for it
solaraslev67
Re: Aftermarket Wheel Question???
Postby indiglosolara » Tue Sep 20, 2005 1:17 pm
M_ABILLONES wrote:Sup guys...new here in this forum...my first question pertains to the bolt pattern of the 1998-01 solara, is it a 5x100 or 5x114? Second, anyone here ever try to cram a 19x8.5 wheel on their Solara? Can it be done without any modification to the fenders? Third, where can I get the 7 pc trd body kit?
Mark
1.The bolt pattern to the Solara is 5x114.3 (5x4.5)
2.Yes you can cram 19x8.5 into the wheel well. I have 19x8.5 wheels. You just need to find the right offset. The ideal offset to run that size is 38 to 35 offset. I have 37offset for my wheels and i dont have any problems. However you will need to roll/cut the rear inner fenders. Its nothing hard to do. A local shop did it for me and cost me $30 bucks each side. I had them cut then they use a sealer to cover up the cut end so it prevents it from rusting.
3.The 7 piece TRD Kit is discontinued however some members may have some on sale used and New. I believe you can contact Mark aka Krazyazn as he might have some new kits in stock.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Solorange » Tue Sep 20, 2005 8:00 pm
solaraslev67 wrote:bolt pattern is 5 x 114.3 and im not sure if it will fit, but i needed to roll the fenders for my 18x8's with 225/40/18 tires, as far as the trd kit, there arent too many around anymore, havent seen a brand new one in a while but some people sell them painted and/or used u just gotta look for it
I think your the first person on this site that has 18's and had to roll the fenders. How come you had to do that with that tire size?
Postby TRD MCV20L » Wed Sep 21, 2005 7:06 am
Wrong offset
TRD MCV20L
Postby kilade » Wed Sep 21, 2005 10:03 pm
what about 19X8 with a 35 offset. do you have to roll up the fenders??
i'm getting a used set w/ tires for $600 and normally i wouldn't go this big but is such a good deal. let me know.
kilade
Postby indiglosolara » Wed Sep 21, 2005 10:42 pm
kilade wrote:what about 19X8 with a 35 offset. do you have to roll up the fenders??
You might need to roll your fenders in the rear.. but it should be ok..
$600 for used??? how used and what size...???
I have a set of almost new only 300 miles on them and they are Toyo proxes T1-R's for $750...which retial for $1000 at local shops.
I bought them and used them at one show only...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Astro » Thu Sep 22, 2005 8:19 am
I've got the 19x8.5 with +35 offset, I guess it would depend on tire size. I rolled my fenders at home. That's a great deal, but what's the condition of these rims?
Postby TRD MCV20L » Thu Sep 22, 2005 6:40 pm
I think he ment that he can get 19 rims with tires for $600
TRD MCV20L
Postby kilade » Sat Sep 24, 2005 5:17 pm
i got the rims. they are 19x8.5 and have 245 35 zr 19 on them. the tires are almost brand new toyo proxes fz4s. it seems like i will need to roll the fenders. i might resell the wheels and just get 18s to save some hussle. it seems way too wide. thanks for the replies
kilade
Postby kilade » Sat Sep 24, 2005 5:21 pm
the rims were actually in fair conditioned. the face has been powder coated and it has a polished lip look. there are scuffs on the back on the wheels but the lips looks in great condition. i'm assuming is a generic brand, 5 split spoke, can't find any label on it. i think i will be able to resell them locally easily. thanks again.
kilade
Postby M_ABILLONES » Sun Sep 25, 2005 3:47 pm
Will a 19x8.5 and a 42 offset wheel fit the 03 solara?
M_ABILLONES
