SolaraGuy.com • View topic - Aftermarket gauges
Aftermarket gauges
Aftermarket gauges
Postby AznDragonV » Thu Nov 24, 2005 6:45 pm
I heard somewhere that aftermarket gauges mess with how fast it shows your going?....is that true?
and is there anything wrong with these:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... Track=true
Thanks
AznDragonV
Postby BradOwens » Thu Nov 24, 2005 6:50 pm
those gauges look nice. as for messing up ur mph...unless u mess up on install it wont change it at all.
BradOwens
Postby PhreakdOut » Thu Nov 24, 2005 6:52 pm
These are templates that replace the OE gauges. So long as the scale is the same, there should be no difference in gauge performance. Just some cool looks.
Postby AznDragonV » Thu Nov 24, 2005 6:53 pm
well i heard it has something to do witht the rpms...or something i dont remember lol
so r these the same as the ones from www.procarparts.com?
AznDragonV
Postby BradOwens » Thu Nov 24, 2005 7:13 pm
AznDragonV wrote:well i heard it has something to do witht the rpms...or something i dont remember lol
there are 2 different kinds on procarparts.com. one of them is the reverse glow gauges which u found and the other is the reverse gauges. personally i like the reverse better than the glow but thts my opinion.
BradOwens
Postby Jon11582 » Thu Nov 24, 2005 7:34 pm
Theres actually at least 4 general kinds
1) White face, regular glow
2) White face, no middle ring, straight letters, reverse glow
3) White face, middle ring, slanted letters, reverse glow
4) Silver face, no middle ring, straight letters, reverse glow.
Beware, there is a batch of the 3rd kind out there that has the 5 and 6 marker on the tach reversed. Make sure to look at the pictures before you get one if you get the 3rd type.
They are simply an overlay, so they wont (and cant) screw up anything if you install them correctly. Your needles never come off the guages, and the labels should be the same.
2000 Black Solara SE
Jon11582
Postby SleeperSolara » Thu Nov 24, 2005 8:41 pm
Yeah mine looks like that.
Also be sure to get the right inverter.
Cause the guy i bought it off on Ebay; made me buy another inverter. :x
But it all good now.
The only bad thing about the fuel and temp guage is that the fuel one is off by alittle. :-?
Postby AznDragonV » Fri Nov 25, 2005 1:11 am
Jon11582 wrote:Theres actually at least 4 general kinds
so which kind were the ones i found? the second one?
o yea and wats an inverter? and how do i know which one i need?
Thanks fo all ur help
AznDragonV
Postby Jon11582 » Fri Nov 25, 2005 1:52 am
U found type 3, which is the same kind I have right now.
It comes with an inverter.
This one looks identical to the one that PCP sells. Theres also another "type 3" on ebay that is only slightly different - The km/h is in blue, its a little brighter, and the cutout is oval instead of cut-to-fit each light (The oval is just a little too small, causing the B in BRAKE to be hidden).
The ones you found are the kind to get in my opinion.
Jon11582
Postby SleeperSolara » Fri Nov 25, 2005 10:57 pm
Jon11582 wrote:Theres also another "type 3" on ebay that is only slightly different - The km/h is in blue, its a little brighter, and the cutout is oval instead of cut-to-fit each light (The oval is just a little too small, causing the B in BRAKE to be hidden).
Yeah mine is like that undoruntaley. :(
But hey all i care is that at least it will show it somewhat.
I'm just glad i'm the only only so far that has re-wired the inverter to only light up blue instead of green or blue.
Cause i didn't want another dimmer or switch. 8)
Check mine out.
Re: Aftermarket gauges
Postby pythonjosh » Fri Nov 25, 2005 11:12 pm
AznDragonV wrote:I heard somewhere that aftermarket gauges mess with how fast it shows your going?....is that true?
Thanks
I think it's funny how they have the tach and gas/temp gauges on the wrong sides. :drinking:
pythonjosh
Postby Too Bzy » Wed Nov 30, 2005 12:30 pm
SleeperSolara wrote:Check mine out.
Okay been meaning to ask this for a while...someone on here has gauges like these but they don't have the dark ring in the center. Who has those and where did they get them?
Charles "Cee-Jay" Hughes
99 TRD Solara S/C LB GP Ed. 23 of 35
86 Supra w/ 6M-GTE
Too Bzy
Postby Jon11582 » Wed Nov 30, 2005 1:51 pm
Without the ring is type 2 and 4 as i referenced above, depending if you want white or silver face.
I installed my friends silver face ones, which I got at procarparts. I dont like the center ring, but I like the bold, italicized numbers that only come on the ones with the rings in the middle. (The numbers on the one without the ring are all straight, normal font.)
Jon11582
Postby solaraslev67 » Wed Nov 30, 2005 2:02 pm
yeah make sure yours dont look like mine :-?
solaraslev67
Postby '00vegas-solara » Wed Nov 30, 2005 2:18 pm
Does any one make reverse glow for the 5 speed. I'm afraid the area where the auto markers are would look strange during the day with noththing there.
'00vegas-solara
