SolaraGuy.com • View topic - k&n drop in filter
k&n drop in filter
k&n drop in filter
Postby Eddiman » Fri Jan 24, 2003 11:51 am
I just got my k&n filter and it cost me like 40bux. But one problem the little hinges on the air box do not slip in so there is a little gap. Am I doing something wrong? do i need to hit the box so it can sit in or what? Cause i know with a slightly open air box will make more noise
Eddiman
eh?
Postby NOSDOG79 » Fri Jan 24, 2003 7:14 pm
Turn the drop-in filter right side up!
I don't know... I'm not trying to be funny, but why wouldn't the hinges clamp on?
I have the TRD drop-in, and didn't have any problems with the hinges.
Neal
NOSDOG79
Postby NASTY » Fri Jan 24, 2003 7:28 pm
yeah, make sure the filter is sitting right, all i can think of
and sometimes the clips are stiff, use a bit more force
'01 SLE V6
NASTY
Postby Eddiman » Sat Jan 25, 2003 11:59 am
my car is a 2002 so the filter that i order could it be the wrong size, because i ordered the one for the 2002 solara.
Eddiman
Postby Eddiman » Sat Jan 25, 2003 12:27 pm
okay i took out the k&n on my 2002 solara and put in the stock airfilter. Okay this is my problem, the hinges will clamp but there is a gap on the left end of the air box. It just seems like it just will not fit i have tried fliping it and still nothing, I think i will return it or just keep it and try to get it to fit, so i guess i will go with the stock air fliter. any advice to make it work let me know someone...anyone ? :(
Eddiman
Postby Eddiman » Sat Jan 25, 2003 12:36 pm
okay its the right model, the darn thing is just kinda thick so it wont sit in all the way.
Eddiman
Postby Jackass-Jeff » Sat Jan 25, 2003 1:55 pm
02 solara i4 should be part #
33-2145-1
mine didnt have a gap but the damn clamps were hard to get back on *_*
just jiggle it a lil bit and the cover should fit perfectly (the hindges = ass)
1GR-FE ftw!
Jackass-Jeff
Postby Eddiman » Sun Jan 26, 2003 10:49 pm
I have the right part. I know that, but the lil hinges on the left side of the airbox that keeps the box sealed doesnt not close, i can get the metal clamps on but not the lil hinges on the left side..im thinking i should take it to the dealership for them to do it...any other suggestions? should i just get the trd drop in?
Eddiman
Postby Danny » Sun Jan 26, 2003 11:10 pm
get the trd drop in. :)
Danny
Re: .
Postby Jackass-Jeff » Sun Jan 26, 2003 11:20 pm
Danny wrote:get the trd drop in. :)
double the price, and just the same as k&n =]
1GR-FE ftw!
Jackass-Jeff
Re: .
Postby NASTY » Tue Jan 28, 2003 2:16 pm
xravexboix wrote:double the price, and just the same as k&n =]
well, not EXACTLY the same...
'01 SLE V6
NASTY
Postby Eddiman » Tue Jan 28, 2003 5:40 pm
whats the difference? which one would give you more hp? and which one is over more better ?
Eddiman
Postby krook » Tue Jan 28, 2003 9:02 pm
i don't think there's THAT much of a difference in hp, if there is any significant gains. just jiggle that bad-boy on there and force them clips on! take your aggravations out on it. sometimes i get a hard time with even the stock air filter!?!
krook
Postby Guest » Thu Jan 30, 2003 8:31 am
yeah, i bet it's not the filter, but the housing. you need to get the cover on just right in order for it to close properly.
Guest
Postby Eddiman » Thu Jan 30, 2003 10:30 am
damn air box housing that wont close errrrrrrrrrrrrr :evilbat: ill keep trying thanks again you guys
Eddiman
