SolaraGuy.com • View topic - gen 2 rims on gen 1 solara wheel spacer question
Postby returnofthedack » Fri Mar 03, 2006 10:13 am
i've had my custom powdercoated gen 2 rims for a while now, and im finally gonna get some damn tires to put them on. for the wheel spacers, where can i get them and should any tire shop (like mr. tire for example) have them in stock ? let me know thanks! if this has been asked, my bad.
www.seandackermann.com
The only person that can stop you in life, is yourself
returnofthedack
Postby Jai_Jai_Binks » Fri Mar 03, 2006 11:02 am
I'm not sure what Mr. Tire, but you are correct any tire shop that sells' aftermarket wheels should have them in stock.
Have you researched to decide if your going with what side spacers, 5mm or 10mm.
My suggestion would be for you to take it to a tire shop for 'mounting' the tires on the wheels...there the tire shop at that time can suggest (and at most times try) all spacer sizes to give you a snug fit.
EDIT: FYI - my other car (gen 4 camry) has gen 5 Camry wheels without spacers. I was told that i needed 5mm spacers, but the tire shop said it fit perfectly well w/o them...Also when i had IS300 rims on my solara, i needed spacers..so it all depends on your setup!
Postby SleeperSolara » Fri Mar 03, 2006 11:04 am
I think 5mm would be best, 10mm would be too big IMO.
But i could be wrong.
Wanted to know what the spacers sizes for the Gen2 rollers on the Gen1.
Users browsing this forum: Majestic-12 [Bot] and 37 guests
