SolaraGuy.com • View topic - What kind of lamps did you use in your corner lenses????
Postby Russian Guy » Fri Jan 31, 2003 3:51 pm
Today I bought PIAA Xtreme White 1157 27/8W lamps. WHAT a DISASTER !!!! :( What can you say about other producers???
1MZ-FE TRD S/C. 2 BLITZ NUR Spec mufflers. SPA Boost/Fuel + Revotec water/oil/volt gauges. BLITZ Powermeter ID III, Denso IK 22 Iridium, TRD brake lines, TRD rear sway bar, fuel pump upgrade
Russian Guy
Postby krook » Fri Jan 31, 2003 6:41 pm
how bad can they be?? pics?
try silverstars' replacement bulbs 1157.
krook
Postby FLASH » Sat Feb 01, 2003 8:53 pm
I don't know the Brand Name, but at my local Pepboys they sell Titanium Bulbs that light up amber for 5.99 each. I would try them, unless you want white, but they make the titaniums that light up all colors, including white. But I think that's illegal...
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby happy_aggies » Mon Feb 03, 2003 8:50 am
I use APC Titanium bulb. $5.99
Looks silver, but lights up amber. :D
It's not dot approved though.
happy_aggies
Postby FLASH » Mon Feb 03, 2003 2:40 pm
Aggies - If there not DOT approved, does that make them illegal?
==FLASH==
FLASH
Postby happy_aggies » Mon Feb 03, 2003 2:50 pm
Yup. It's not DOT Approved means (theoritically) it's not legal for street application.
It's for show, off-road use only.
Anyway, I don't think that you will get pulled over because of the Titan bulb, since it still emits amber light when flashes/on. It just not as bright as the OEM since it has metallic tint.
happy_aggies
I disagree
Postby JMSinMaryland » Mon Feb 03, 2003 3:27 pm
I have the 'euro' clear corners that look similar to the headlights with those APC bulbs and I actually think it's brighter than the OEM corner with amber bulb. Just my opinion. Jon.
JMSinMaryland
Postby Flipside909 » Mon Feb 03, 2003 4:31 pm
FLASH wrote:Aggies - If there not DOT approved, does that make them illegal?
DOT doesn't approve ANYTHING. They do however set standards and guidelines that aftermarket companies abide by in order to make a product street legal.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Ferrari_1299 » Wed Feb 05, 2003 2:55 pm
Go with the APC titaniums I have them and they look awsome.
1999 SE V6
Eibach Springs, Tokicko Struts, CF Hood, Custom Grill, Clear Corners, more to come...
http://www.cardomain.com/memberpage/275185
Ferrari_1299
Postby Guest » Sat Feb 08, 2003 9:25 am
Just to update, I put in the Titaniums, and they are well worth the 12 bucks.
Guest
Postby ICrazyChrisI » Sat Feb 08, 2003 1:01 pm
Im rockin the APC Titans :D
ICrazyChrisI
