SolaraGuy.com • View topic - Rims, rims, rims
Rims, rims, rims
Rims, rims, rims
Postby JAYDEE23 » Sun Apr 09, 2006 4:53 pm
gotta couple of not so standard questions..
In the market for new rims for my solara
Regarding offset. In a perfect world we would increase rim width equally on both sides to retain maximum performance? Is my thinking correct? I am aware of the "offset thread" but i am finding some manufacturers claiming a 7.5" will fit just fine with standard 45+ offset..this true?
also i have some choices in what offset i can choose for 7.5" or 8.0" rims which all fall in the "it will work" category but i would like to know which number would be optimal for performance/longevity
I am not looking to sacrafice anything for the look...unless i have to of course 8)
JAYDEE23
Postby JAYDEE23 » Sun Apr 09, 2006 4:57 pm
also i was pretty sure i wanted this rim..any feedback on the quality of these rims?
Ultra Wheel
Not expensive but not dirt cheap...
http://www.ultrawheel.com/wheel_detail. ... nd=1&id=94
Problem is this wheel comes in 38 offset for 7.5" wide..freakin rim shopping sucks :-?
JAYDEE23
Postby RichD978 » Sun Apr 09, 2006 5:44 pm
I have 35 offset for 7.5 wide. No complains
RichD978
Postby JAYDEE23 » Tue Apr 11, 2006 3:45 pm
no one knows if or what the correct optimal offsets would be as width increases?
JAYDEE23
Answer
Postby JMSinMaryland » Tue Apr 11, 2006 8:41 pm
Either an 18x7.5 with 45 mm offset or 18x8 with 40 mm offset. I recommend a 225/40 18 with either one. There's not going to be a noticeable difference in handling or looks anyway you go b/t the 2. Jon.
JMSinMaryland
Re: Answer
Postby Solorange » Thu Apr 13, 2006 9:16 pm
JMSinMaryland wrote:Either an 18x7.5 with 45 mm offset or 18x8 with 40 mm offset. I recommend a 225/40 18 with either one. There's not going to be a noticeable difference in handling or looks anyway you go b/t the 2. Jon.
Are you sure a 7.5 wide rim with a 45mm offset will work??? Cause I have a 7.5 wide rim with a 35mm offset and I only have a fingers distance between the rim and the strut.
Yes
Postby JMSinMaryland » Thu Apr 13, 2006 9:19 pm
I have run an 18x7.5 with 45 on both my 01 Solara (dropped with TRD suspension) and 99 Camry (dropped with TRD Suspension). Jon.
JMSinMaryland
Postby Solorange » Fri Apr 14, 2006 1:36 pm
How close was it to the struts when you ran that setup?
Great Fit
Postby JMSinMaryland » Fri Apr 14, 2006 4:50 pm
It's as close to an OEM fit as you'll find. I had the car loaded down with 5 people and no rubbing. Jon.
JMSinMaryland
Postby toy4x4boy » Sat Apr 15, 2006 8:04 am
I run 18x8 with 42 offset on 225/40-18's and they fit perfect and fill the wheelwells much better than the stockers.
toy4x4boy
Users browsing this forum: No registered users and 106 guests
