SolaraGuy.com • View topic - synthetic oil
synthetic oil
synthetic oil
Postby Guest » Tue Feb 04, 2003 8:41 pm
Im running my engine on conventional oil right now. If i switch to synthetic do i have to stay in synthetic for life or is it ok to switch back to conventional at some point?
Guest
Re: synthetic oil
Postby Flipside909 » Tue Feb 04, 2003 9:16 pm
Anonymous wrote:Im running my engine on conventional oil right now. If i switch to synthetic do i have to stay in synthetic for life or is it ok to switch back to conventional at some point?
You have to stay with synthetic once you switch.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby happy_aggies » Tue Feb 04, 2003 10:41 pm
I thought you can switch back when you get high mileage?
happy_aggies
Postby Flipside909 » Wed Feb 05, 2003 1:27 am
happy_aggies wrote:I thought you can switch back when you get high mileage?
Hmm really? i never heard of that. Most everyone i know who has used synthetic has stuck with for a long time.
www.clublexus.com
Flipside909
Postby happy_aggies » Wed Feb 05, 2003 8:01 am
I was told that it's better to use regular oil when we have high mileage,
so I am thinking we should switch to regular when we reach the high mileage.
happy_aggies
What I've Heard
Postby JMSinMaryland » Wed Feb 05, 2003 8:26 am
What I heard was that you shouldn't switch back and forth, also if you have always had dino you shouldn't switch to syn at high mileage, but it's ok to have syn at a high mileage if you've always had it. Personally Im still going to do oil changes at 3,000 miles so it's not worth the price of syn vs. benefits of syn to change it out so often. I use a syn blend right now myself with Toyota filter. Jon.
JMSinMaryland
Postby Yanks0114 » Wed Feb 05, 2003 8:41 pm
Synthetic oil is not meant to be used on high mileage cars because the oil is so thin and over time little pours have developed in the engine block which cause leaks. If you run synthetic now with under 75k miles, you can keep it forever, but if you are over 75k miles don't switch. Also i don't reccomend switching back. Don't know why you would either
