SolaraGuy.com • View topic - Who is using or has used LED's
Postby Sap Z » Mon Apr 24, 2006 11:17 am
Secially on the exterior including corners, license plate , brake etc
if you have did you have any issues with short circuiting or any other electrical issues since the LED's use up less current?
I had LED corners in my previous car n i had electrical probs. so just wondering.
I saw on Ebay that with LED bulbsd you can also buy a load resistor which will help to make the blnking or corners at normal speed instead of hyper blinking.
any comments?
SapZ
V6 SE DWP
Sap Z
Postby '00vegas-solara » Mon Apr 24, 2006 1:10 pm
I have the Corners, rear turn and Tail lights all using LED's. The turn signals will have hyper flashig but it can be resolved by getting an electronic flasher that is not load dependent. I would stay away from the resitor method as they get very hot as they are taking the place of the filiment.
'00vegas-solara
led's
Postby trd4life » Mon Apr 24, 2006 7:57 pm
i have them in license plate lights. they work great.
Postby CASTRO » Mon Apr 24, 2006 8:07 pm
dont use em for the gauge cluster... i've wasted so much money since they kept on going out on me...
CASTRO
Postby '00vegas-solara » Mon Apr 24, 2006 8:41 pm
I've also done my gauges and climate control with LED's. You have to be careful with voltage when you use LED's or they will pop on you.
Heres a few pics.
'00vegas-solara
Postby Duffman » Mon Apr 24, 2006 9:24 pm
Sap Z - I've got LEDs over the license plate. Depending on where you get the LEDs (or if you make them on your own), most decent ones will have a resistor wired up with them that will decrease the voltage from 12v to something the LED can use (for many, around 3.3v). I'm not certain whether or not that resistor would convince the fuses that everything is okay, but I've yet to have a blown fuse. I've got LEDs in the gauge cluster right now, but as soon as my Super Whites come in (Xenon gas bulbs), those will come out - I could never get the light to look even enough, and I tried everything shy of wiring up 50 of the surface mount LEDs to the back of the cluster (which would be awesome, if I had that kind of patience and soldering experience!).
Vegas - lookin' good... but HOW THE HELL did you get to the HVAC controls? I've been trying for about a week now to figure out how to get around that [censored] green tube cable... thing. I've got a few ideas for the HVAC controls, with white LEDs lighting everything but the cold/hot knob (red and blue, respectively), but damned if I can't get to it.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
LED Voltage
Postby Sentinel » Mon Apr 24, 2006 10:00 pm
If you can only get LEDs that can handle 3 volts, why dont you wire 4 LED's in series? Kirchoff sez the voltage across each (with equal resistance) will be 1/4 the total voltage. Resistance will also be 4 x. Might help with hyper-blink.
Sentinel
Postby NeFaRiOuS_SLE » Tue Apr 25, 2006 1:44 am
I have LED license plate bulbs to try to mimic the GS, but it's not doing a great job since it's not as white as I would prefer, nor is it as bright (but hey, it'll be worth its weight in gold as soon as I get around to the point where I can smash eggs at some of my old job places that ripped me off).
Postby woa_its_j3ff » Tue Apr 25, 2006 5:41 pm
I have LED's as turn signals and as license plate lights.
Reply
Postby JMSinMaryland » Tue Apr 25, 2006 5:42 pm
I think LEDs are cool.
JMSinMaryland
Postby hskrsolara » Tue Apr 25, 2006 6:04 pm
EDIT: hey VEGAS, what did you use to fill the turn signal holes (the orange stuff)? it looks good.
-sorry duff, got the pictures mixed up, i was really asking vegas.
hskrsolara
Postby Sap Z » Tue Apr 25, 2006 8:48 pm
^^hey jeff are ur turn signals hyperblinking?
SapZ
V6 SE DWP
Sap Z
Postby Duffman » Wed Apr 26, 2006 8:13 pm
hskrsolara wrote:hey duffman, what did you use to fill the turn signal holes (the orange stuff)? it looks good.
That was Sap Z's work, not mine - however, I'd suggest a simple piece of clear plastic (like, from a soda bottle or a package) with 1) some Sharpie lovin', or 2) colored cellophane, or 3) the blood of a virgin, or 4) maybe some kind of nail polish. I think the cellophane would give the most uniform color, but the virgin blood has a certain panache to it.
Duffman
Postby Sap Z » Wed Apr 26, 2006 8:45 pm
^^^ i'm not sure wat u guys are talking about? what signal holes?
SapZ
V6 SE DWP
Sap Z
Postby NeFaRiOuS_SLE » Thu Apr 27, 2006 2:38 am
Vegas, with the alternate flasher in mind, does the "bulb out" light come on?
Users browsing this forum: Google [Bot] and 56 guests
