SolaraGuy.com • View topic - K&N Reusable Air Filter Help with gas mileage?
Postby 01SolaraV6 » Wed Apr 26, 2006 10:44 am
Does it?
2001 Solara SE V6 (5speed) Silverstream Opal
Loaded
01SolaraV6
Postby Somedude » Wed Apr 26, 2006 10:50 am
I don't have a K&N performance air filther on my car yet but they should give you better gas milage since there is less restriction on the intake system with the K&N filther installed.
The biggest factor in determining gas milages are your driving habits. My car seldom hits more than 3000 rpm during driving. My car most often goes only 2500 rpm while I am driving.
Obeying speed limit is not only safe but it can also help with getting better gas milages. I know sometimes that obeying speed limit is not the safest choice, especially if you have to pass somebody quick.
Somedude
Postby Sap Z » Wed Apr 26, 2006 11:09 am
not really. i mean it probably does but its not at all noticeable. these hav ebeen many posts here regarding that. do a search.
the main change i noticed was the engine noise - its a lot more throatier.
you can forget about geting more power or gas milage (unless ur current air fillter is full of poop!)
SapZ
V6 SE DWP
Sap Z
Postby Somedude » Wed Apr 26, 2006 11:16 am
Sap Z wrote:not really. i mean it probably does but its not at all noticeable. these hav ebeen many posts here regarding that. do a search.
When I remove the air filther box, should there be a sound filther in there as well? I remember some members here saying that they removed it while installing their K&N performance air filther.
How much should one cost? around $40.00?
Somedude
Postby Sap Z » Wed Apr 26, 2006 12:24 pm
sounds filter?!?!?! umm..theres nothing like a 'sound filter'
open the box by unclipping the clips and u'll c the air filter. thts it.
autozone sells it for $45 i believe.
SapZ
V6 SE DWP
Sap Z
Postby TheTamago » Wed Apr 26, 2006 1:06 pm
I think he's refering to the sound dampener. I'm pretty sure someone with this filter has done it. I have a TRD Filter but I'm not interested in sound yet.
TheTamago
Postby Somedude » Wed Apr 26, 2006 2:20 pm
will the car's engine get damaged if I remove the sound dampener? I plan on installing the K&N performance air filther sometime soon.
Somedude
Postby xavier » Wed Apr 26, 2006 3:22 pm
Im pretty sure the sound dampener just muffles the "suck" :lol:
xavier
Postby Duffman » Wed Apr 26, 2006 8:08 pm
Mmm, suck. It's been my experience that the sucking itself will muffle most sound.
All lamentations on my lackluster love life aside, I'll gladly vouch for the K&N filter. If nothing else, it pays for itself in the long run if you plan on keeping your car "until it runs into the ground", as it were. The freer-breathing qualities of the filter will give your engine more access to its power, across a broader torque range than a stock filter would. I actually prefer the K&N over these $200 CAI units, as the price ($40) for the performance (estimated 2-3hp, and a larger power band) is MUCH better (versus over $200 for 6-7hp). It also sounds sexy, like when you're leaving the parking lot an hour and a half into your prom night. But I digress. You will also get a slightly better gas mileage, though the actual numbers from my experience seem to only equate to another 20-25 miles on the same amount of gas in a full tank. But hey, gas is gas.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby Somedude » Wed Apr 26, 2006 8:14 pm
but will removing the sound dampener be damaging to the engine?
if not, then I will remove the stock air filther and the sound dampener and just put the K&N performance air filther in place.
Somedude
Postby StockSolara » Wed Apr 26, 2006 11:22 pm
Somedude wrote:but will removing the sound dampener be damaging to the engine?
When you say that and are referring to that white containter connected to the snorkel. . . Than no it won't damage your engine
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Fletch » Thu Apr 27, 2006 3:46 am
There are 2 resonators in the stock air delivery system. The black one between the MAF and throttle body and the big white one sort of under the filter box, remove the wheel well liner for easy access.
I had both of them removed and a K&N drop in. A little louder intake noise but not much, no affect on fuel ecomomy.
I got 26 mpg HW and 18-21 City, using BP 93 & SAE 30 oil.
2006 Legacy GT spec.B
Fletch
