SolaraGuy.com • View topic - CPE intake
CPE intake
CPE intake
Postby SdeA » Tue May 02, 2006 11:40 am
i install the cpe intake into my car but the engine start at first but then the rpm began to reduce and then it shut down i try to adjust all the hose and stuff. I think it could be the air sensor what do you guys think please help. :(
SdeA
Postby black99 » Tue May 02, 2006 11:44 am
To quote Lewis Black:
"Verbs....... Verbs eluded him"
99 SLE auto- Tein/Tokico combo- TRD RSB- 20% tint all around- 50% windshield- custom grill- Alpine 9857- Alpine Type R comp's- Type S 6x9's- Alpine MRP-M1000- 2 JL Audio 12W3v2- "blacked out"
black99
Postby theprodigy79 » Tue May 02, 2006 12:02 pm
Did you make sure that you installed the customizer properly?
Make sure that all of the connections are on the proper wires, if not you can get in some serious trouble...
Also, if you used the 'scotch locks' supplied, make sure that they fully cut through the insulation and are making a solid connection with the bare wire. If they aren't making a good connection it could short out or not function properly.
has your check engine light come on?
theprodigy79
Postby SdeA » Tue May 02, 2006 12:26 pm
Did the CPE intake come with a 3.5 MAF sensor??? Because i bought mine from jhenty and i didnt see the MAF... could that be the problem?
SdeA
Postby theprodigy79 » Tue May 02, 2006 1:15 pm
It absolutely comes with the MAF customizer. It's a small black box with a cable hanging out of it... That is REQUIRED for the car to run properly (if not at all)
theprodigy79
Postby SdeA » Tue May 02, 2006 1:22 pm
I just PM jhenty about the missing MAF sensor hope he will reply back soon :roll:
SdeA
Postby SdeA » Tue May 02, 2006 1:31 pm
What about the sensor??? so the sensor we will be using are stock??
SdeA
Postby Hsakuragi » Tue May 02, 2006 1:35 pm
make sure ur rubber hose is completey tighten to the throttle body
Hsakuragi
Postby theprodigy79 » Tue May 02, 2006 4:52 pm
Yes, the sensor is the stock one.
theprodigy79
Postby theprodigy79 » Tue May 02, 2006 5:04 pm
Here's what you shoulda received:
The pic shows everything except the heat guard (which the Gen 1 and 1.5 come with). The materials shown in the picture are:
CP-e MAF Customizer - the black box with the wires, far left
Rubber 2.75" to 3.5" gasket to connect SRI to throttle body (stamped CP-e)
2.75" and 3.5" ring clamps
CP-e Short Ram Intake
aFe Air Filter
rubber shock absorber / spacer (the little black cylinder)
Manual
theprodigy79
Postby krook » Tue May 02, 2006 5:10 pm
recheck your engine bay to see if anything was left unplugged. my car ran the same way after i installed my Injen SRI, and when i took it to Toyota and they located a free-hanging plug they looked at me like...
"are you f*ckin' kiddin' me...?!!"
krook
Postby Solorange » Tue May 02, 2006 7:33 pm
That black box (MAF customizer) looks like its too big to fit on top of that mount for the intake in that picture. Where does that go and how does that connect into the car.
Postby theprodigy79 » Tue May 02, 2006 8:48 pm
Solorange wrote:That black box (MAF customizer) looks like its too big to fit on top of that mount for the intake in that picture. Where does that go and how does that connect into the car.
It splices in to your ECU behind your glove box. Basically a piggy back that "tricks" your ECU into calculating the proper amount of air the engine is taking in due to that .75" increase in pipe diameter (this is what would cause the stalling and improper engine functioning)... It also contains the new, performance oriented, fuel map.
theprodigy79
Postby SdeA » Wed May 03, 2006 12:30 am
I install the MAF customizer udnerneath the glove box. Then when i start the engine the rpm is at 1000 and the check engine light is on...What should i do???
SdeA
Postby dvdchris45 » Wed May 03, 2006 12:40 am
The smog shops are gonna have a field day with this one...
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
