SolaraGuy.com • View topic - Crank Pulleys
Crank Pulleys
Crank Pulleys
Postby Solorange » Tue May 02, 2006 8:19 pm
I was reading through my March Issue of Modified mag (I know two months late) and I was looking at the tech article where they added a lightwieght Crank Pulley. I ran a quick search to see if they make them for solaras, but came up empty. Just a bunch of posts on supercharger pulleys. Anyway Modified mag claims that it will add about 10hp due to less rotating mass. This looks like a cheap easy mod I can throw in under an hour and if their claim is right, then its good for a cheap good power increase too. So does any companies make one for our cars?
Postby krook » Tue May 02, 2006 8:23 pm
isn't there a Fidanza flywheel, or is that only for M/T solaras??? i've seen them on ebay, and i think URD sells 'em too.
krook
Postby hskrsolara » Tue May 02, 2006 8:26 pm
yep...got mine from horsepowerfreaks.com
hskrsolara
Postby ---CAMRAZY--- » Tue May 02, 2006 8:31 pm
krook wrote:isn't there a Fidanza flywheel, or is that only for M/T solaras??? i've seen them on ebay, and i think URD sells 'em too.
Crank Pulley is not the same as the Flywheel. The Fidanza is for the 5 speed.
Postby krook » Tue May 02, 2006 8:38 pm
oh, kay thanks. i was confusing the Fidanza flywheel with this one:
http://cgi.ebay.com/ebaymotors/Unorthod ... enameZWDVW
krook
Postby Ian » Tue May 02, 2006 9:06 pm
URD has the closest thing to what you are looking for. Check out their website www.urdusa.com
Ian
Postby Astro » Tue May 02, 2006 11:29 pm
^Yeah, I'd contact URD, they had them. I don't see it listed on their site anymore, but I've got one.
Postby DaTwUnKrAziEpInOy » Tue May 02, 2006 11:42 pm
Yeah.....I recently e-mailed URD and they don't sell the Crank pulley's for the Solara anymore. :(
DaTwUnKrAziEpInOy
Postby dominoSLEV6 » Wed May 03, 2006 1:16 am
What? No more crank pullies for us? URD was where it was at for those.
-chris
dominoSLEV6
Postby Ian » Wed May 03, 2006 7:00 am
DaTwUnKrAziEpInOy wrote:Yeah.....I recently e-mailed URD and they don't sell the Crank pulley's for the Solara anymore. :(
I wonder why. Maybe low demand, or they probably made one batch and just decided to sell one batch. It looks like a complicated piece to make.
I have one on my Solara and it is a nice piece, works just fine. It looks nice, and I believe it is working better than stock in terms of performance. But, it is kinda hard to tell an increase in horsepower of 10 or below. Every extra hp helps.
Ian
I wonder why. They probably made one batch and just decided to sell one batch. It looks like a complicated piece to make.
Ian
Postby SleeperSolara » Wed May 03, 2006 7:06 am
No i think they just labeled it wrong.
Well just searched on their sight and couldn't find it either. :(
Emailed them though, and will tell you what they say.
And i was about to get one too. :(
Postby lilm » Wed May 03, 2006 9:28 am
ya id be up for it too....i can change a pully :)
lilm
Postby that1mexguy » Wed May 03, 2006 9:59 am
sorry for showing my ignorance (like usual) but what is this again? -- details pls?
that1mexguy
Postby dominoSLEV6 » Wed May 03, 2006 2:49 pm
that1mexguy wrote:sorry for showing my ignorance (like usual) but what is this again? -- details pls?
The crank Pulley? It's just a lighter pulley for your crankshaft. It seems like it wouldn't make much difference, but it frees up some power because its lighter mass has less inertia and is allowed to spin faster, basicly putting more power at your feet sooner. However there are several arguments that it is not good to use a lightweight pulley because it throws off the entire rotating assembly balance and can warp your harmonic balancer over time.
But it's a relatively easy mod for 5-15 hp usually, relative to your other mods.
-chris
dominoSLEV6
