SolaraGuy.com • View topic - Will upgrade Alternator fix this issue?
Postby DatSRBoi » Wed Aug 09, 2006 7:06 pm
Lately with the 100+ temperature Ive been left with no choice but to turn my AC on to stay alive. I notice when I turn the AC on my car idles at 600 rpm and night time I see the light dim and car stuggles to keep going. I have to push the gas pedel to 1000 rpm just to keep the car from going too low on idle. It only does this with the AC on or sometime when I use my window, moonroof, all my lights at the same time but it isnt as bad.
Will getting that higher power amp solve all the problem? Belt and everythings fine. I hate the 600 rpm idle.
Postby Wang2k » Wed Aug 09, 2006 7:22 pm
adjust your cable while the lights are dim till it goes away.
Wang2k
Postby DatSRBoi » Wed Aug 09, 2006 7:26 pm
Wang2k wrote:adjust your cable while the lights are dim till it goes away.
I think I max pulled it out. Wont go anymore.
Postby Wang2k » Wed Aug 09, 2006 7:37 pm
i think i know what you mean, the threads stop then start again right? get a wide nut and it might adjust more, i think i remember thinking that when i was looking at my car.
Wang2k
Postby udonoogen » Wed Aug 09, 2006 8:50 pm
test your battery?
1999 V6 SLE, Diamond White Pearl
udonoogen
Postby Yanks0114 » Wed Aug 09, 2006 9:02 pm
Not sure why its a big deal if your lights are dimmer when you're idling?
The AC on max can really lower power output, especially at idle. An upgraded alternator will help this.
Postby DatSRBoi » Wed Aug 09, 2006 10:11 pm
Yanks0114 wrote:Not sure why its a big deal if your lights are dimmer when you're idling?
Will it help idle though?
Postby StockSolara » Wed Aug 09, 2006 11:40 pm
A grounding kit may help this, if not. Than an Optima Yellow Top will and if that still doesn't work than I would suggest the alternator
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Sp33d » Thu Aug 10, 2006 12:18 am
StockSolara wrote:A grounding kit may help this, if not. Than an Optima Yellow Top will and if that still doesn't work than I would suggest the alternator
totally agree.
have you ever heard of the Big 3? basically upgrading key points for better electrical current to flow through the car. here is a link
http://forum.sounddomain.com/forum/ulti ... =007801;p=
-mark
Sp33d
Postby DatSRBoi » Thu Aug 10, 2006 7:15 am
My battery was recently check, I have groundings too... I think its the alternator then. My idle is killing me.
Postby Paladin06Greg » Sun Aug 13, 2006 2:53 pm
Sounds like your alternator is failing. Better have it checked. It's been 110 (+) here and I never have that ptoblem but, I've got an HO alternator.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby DatSRBoi » Sun Aug 13, 2006 6:34 pm
Paladin06Greg wrote:Sounds like your alternator is failing. Better have it checked. It's been 110 (+) here and I never have that ptoblem but, I've got an HO alternator.
That might be it too. My car battery has died on me twice in the pass month on morning startups. But then I D/C the battery when the cars on, The car doesnt die.
Postby StockSolara » Tue Aug 15, 2006 11:50 pm
Then it may just be your battery is getting old or if you have too much electronics a normal battery can't handle it and you may need the Optima Yellow Top with the Deep Cycle
2000 Lexus GS400
StockSolara
Users browsing this forum: Majestic-12 [Bot] and 41 guests
