SolaraGuy.com • View topic - What O2 sensor are you using with JPP headers?
Postby Astro » Mon Aug 14, 2006 9:59 am
As I noted in another post, I'm getting codes po135 and po155. I just realized that I'm running Denso air/fuel sensors and not O2 sensors. I didn't know there was a difference, but I guess there is :roll: . When UPFD put my headers in, they put in the air/fuel sensors. They also told me that the stock sensors wouldn't work because the wires were too short.
So, I guess by changing these out for the O2 sensors should remove my codes, correct?
Any brand and part #'s anyone can supply me with?
I really want to dyno my car!!!!
Thanks,
Larry
Postby dominoSLEV6 » Mon Aug 14, 2006 8:58 pm
Are you talking about a wideband for a/f readings or just a regular O2 sensor?
-chris
dominoSLEV6
Postby Astro » Mon Aug 14, 2006 11:03 pm
I'm talking about the regular front and rear O2 sensors.
Postby Ian » Wed Aug 16, 2006 9:03 am
I have a 2001 Solara, built in October 2000, and I use the 2 A/F sensors. My toyota dealer/mechanic said that Solaras before the time mine was built likely us O2 sensors.
I think that getting the right sensors, in your case O2 sensors, should solve your problem. I say that because I discussed this issue with Gadget who makes the distinction that you have to use the right sensor, O2 sensor or the A/F sensor, in order to properly tune.
Try sparkplugs.com, which is where I found the Denso A/F sensors. Larry are your A/F sensors Denso part #"234-9021"?
Ian
Postby Astro » Wed Aug 16, 2006 11:10 am
Well, I'm not sure, all I know is that they are universal DENSO air/fuel sensors for CALI and they did cost me about $170 each. I guess part #"234-9021" where only for '02/'03 with auto tranny. I may have this one and that maybe my problem.
When I checked these out on other sites, I noticed sometimes they list for manual or auto. This site doesn't, so I'm not sure if this matters or not.
From what I gathered on sparkplugs.com it says that I use air/fuel sensors for the front and O2 in the rear. I entered in 2000 Solara. From what it looks like only non-cali vehicles use the O2 sensors.
This is what it lists:
Denso  AIR/FUEL SENSOR  234-9007  234-9007  FRONT LEFT
California $162.05
Denso  AIR/FUEL SENSOR  234-9009  234-9009  FRONT RIGHT
California $162.05
Denso  OE identical O2 sensor  234-4137  234-4137  REAR $95.66
I guess I need to get -9007 for bank 1 sensor 1 and -4137 for the rear?
I'm just worried if I'll run into the problem UPFD did with the wire not being long enough.
Postby Ian » Wed Aug 16, 2006 3:05 pm
I would recommend asking Gadget at URDUSA.com. I told him my situation and he says I had to get that particular A/F sensor. Just give him the date your car was made (look on the driver door tag) and he should be able to give you the part number.
Ian
Users browsing this forum: Majestic-12 [Bot] and 41 guests
