SolaraGuy.com • View topic - Strut Mounts - KYB or TOKICO?
Which mounts should i get?
KYB
1
33%
Tokico
2
67%
Total votes : 3
Postby anttarz » Tue Aug 22, 2006 2:27 pm
I got new TRD (Bilstien) struts and TRD (Eibach) springs thanks to solaraguy members. I cant decide whether to get KYB or Tokico strut mounts. I originally thought of getting Toyota oem mounts but they quoted me at $290 w/ a dealer courtesy discount. I cant even remember if that included bearings. Ive found KYB and Tokico for around 200. I've heard cases with different toyotas where the KYB rear mounts didnt match stock and caused some issues. Any suggestions?
anttarz
Postby ---CAMRAZY--- » Tue Aug 22, 2006 2:34 pm
They make strut mounts???? Whats wrong with the stock ones??? Thats what I would use.... The ones that are there now...
Postby anttarz » Tue Aug 22, 2006 2:40 pm
yea they do...
KYB part #SM5180, SM5179, SM5175
Tokico part #HK38017, HK38018, HK38041
They are messed up, i can hear my current struts rattle when i hit bumps, especially the front left. A mechanic i know told me they need to be replaced, plus it cant hurt the suspension.
anttarz
Postby Sp33d » Tue Aug 22, 2006 2:57 pm
the problem you are having right now is a problem many of us are getting from the bilstein struts sold to us by krawzyazn.
from what i have been hearing, what you need to do is a get a rubber bushing that will fit in between the top of the strut mount and the strut mount itself. hope this helps, alot of us are in the same boat. you wont need new strut mounts, believe me.
hopefully when krawzyan finds out the TRD part that stops the rattling, we will all be saved, until then, well see.
-mark
Sp33d
Postby anttarz » Tue Aug 22, 2006 3:02 pm
Sp33d wrote:the problem you are having right now is a problem many of us are getting from the bilstein struts sold to us by krawzyazn.
-mark
The noise is coming from my stock suspension, i havent installed the new TRD one yet. The rubber bushing you are refering to is the "Spring Upper Seat" or the Bearing?
anttarz
Postby DaTwUnKrAziEpInOy » Tue Aug 22, 2006 3:07 pm
I'm surprised that Kyb and Tokico make strut mounts.
DaTwUnKrAziEpInOy
Postby hskrsolara » Tue Aug 22, 2006 4:32 pm
kyb, search and you will find some sites that sell them cheap.
hskrsolara
Postby indiglosolara » Tue Aug 22, 2006 4:37 pm
-mark
Where can you find the Spring Upper seat?? My friend installed the TRD struts and is getting the rattle. Like Mark mentioned above allot of ppls are having this problem and are looking for a solution. Any help or links to the bushings will be helpful to others.
I am trying to help out my friend and others on the forum so any knowlegde on a resolution is greatly appreciated.
Thanks
Regards,
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby anttarz » Tue Aug 22, 2006 6:16 pm
here is a strut tower diagram to help those who are not famillar with all the parts:
http://chrisp.org/~kubi/solara/Strut_Spring_Install.pdf
anttarz
Users browsing this forum: Majestic-12 [Bot] and 41 guests
