SolaraGuy.com • View topic - Six-speeds
Six-speeds
Six-speeds
Postby Ollin » Thu Aug 31, 2006 11:27 pm
Ok just because I have to have everything about my car straight custom(car club name). The new 07 Camry has a six-speed tranny. Could it be applied to my 2az-fe. The engine base is the same with a few tweaks here and there. If it would work besides the obvious space and cost issues could there be anything else I might run into.
Ollin
Postby Mandarinsolara » Mon Sep 04, 2006 2:40 pm
yea man the 6 speed plugs right onto the 2az-fe. tell us how fast and custom it is when you are done.
Mandarinsolara
Re: Six-speeds
Postby Sebas007 » Mon Sep 04, 2006 6:33 pm
I'm not a swap expert...but careful to what you read. I would ask CamrySE-soCALlara he did some engine swap and maybe some tranny swap.
The new Camry I4 hasn't the 6-speed tranny !! The 2GR-FE doesn't have the same base as the 2AZ-FE...be aware
Ollin wrote:Ok just because I have to have everything about my car straight custom(car club name). The new 07 Camry has a six-speed tranny. Could it be applied to my 2az-fe. The engine base is the same with a few tweaks here and there. If it would work besides the obvious space and cost issues could there be anything else I might run into.
Postby PhreakdOut » Mon Sep 04, 2006 6:47 pm
Tranny swaps are NOT just unbolt one and swap. The 5spd and 6spd are electronicaly controlled thus the ECU needs reprogramming.
Postby Jon11582 » Mon Sep 04, 2006 7:16 pm
Isnt the 6spd in the new Camry ONLY for the 2GR-FE? If so, I dont think theres a chance in hell it will fit on a 2AZ.
2000 Black Solara SE
Jon11582
Postby Jackass-Jeff » Tue Sep 05, 2006 7:17 am
Camry trannys do not bolt on like that. The 6AT is for the 3.5 2GR-FE while the 2AZ only has a 5AT which is likely to bolt on, but it was designed for the ACV30 platform, not ACV20 so the fit may not be perfect.
Not worth it =P If the tCs pulling crazy power get enough attention aftermarket transaxles might get made for better gearing through all that power... but it's still doubtful. Afterall, FWD is basically only good for drag right? =P The torque steer kills everything.
Jackass-Jeff
Users browsing this forum: Majestic-12 [Bot] and 41 guests
