SolaraGuy.com • View topic - rsb getting loose?
rsb getting loose?
rsb getting loose?
Postby calreef18 » Tue Sep 26, 2006 12:40 pm
Hi all, I installed my rsb a couple weeks ago and the difference was great, the car stayed really flat in turns. Two weeks later, the car seems sloppier again, with more body roll. What could be the problem? The sway bar link nuts are tight, and I can check the other mounting bolts but I'm pretty sure they're fine. Did I just get used to the car?
calreef18
Postby DaTwUnKrAziEpInOy » Tue Sep 26, 2006 12:44 pm
Maybe you already got used to the car. I forget sometimes that I have one too. If your mounts are loose....you'd hear a rattling sound of somesort.
DaTwUnKrAziEpInOy
Postby calreef18 » Tue Sep 26, 2006 12:45 pm
Dammit say it ain't so lol... it feels like stock again.
calreef18
Postby Down2TheC » Tue Sep 26, 2006 12:45 pm
You'd be hearing stuff it the RSB was loose enough to allow more roll. The brackets or the ball joints would have to be loose.
Down2TheC
Postby calreef18 » Tue Sep 26, 2006 1:57 pm
Ok so everything is tight, brackets, links, tried shaking the sway bar and nothing, maybe I just need to go with coilovers/stiffer struts/different car.
calreef18
Postby DaTwUnKrAziEpInOy » Tue Sep 26, 2006 2:18 pm
What do you have so far for suspension ??
Oh yeah.... there is a Sale @ Jic-Magic for their FLT-A2 coilovers for the Solara. Just thought I'd share.
DaTwUnKrAziEpInOy
Postby SleeperSolara » Tue Sep 26, 2006 2:25 pm
DaTwUnKrAziEpInOy wrote:Oh yeah.... there is a Sale @ Jic-Magic for their FLT-A2 coilovers for the Solara. Just thought I'd share.
:o :o
Anyways.
Did you put the RSB on track settin'??
Postby PXLpainter » Tue Sep 26, 2006 2:33 pm
I probably don't need to ask this, but do you have your RSB at the inner-most setting? Do you have the FSTB as well? That made a HUGE difference for me in addition to the RSB.
I still have the stock SLE shocks and tires, but I still feel a nice tight control as is.
Postby calreef18 » Tue Sep 26, 2006 7:05 pm
Tein/tokico's and yes track setting innermost hole.
calreef18
Postby SleeperSolara » Wed Sep 27, 2006 6:30 am
calreef18 wrote:Tein/tokico's and yes track setting innermost hole.
You might want to check all the bolts and make sure their on there tight.
If they all are, than i think you're gettin' used to the car....
