SolaraGuy.com • View topic - is bumper removal required for installing fog HIDs?
Postby xcgames » Tue Oct 03, 2006 1:46 pm
I got a set of 3000k kit that i'm going to replace the factory OEM fog light with. I took a quick look under my car and the entire fog light housing is blocked with screws seems to be driven into the bumper... Do i need to take off the whole bumper to install the fog kit?
i also went through 2001 camry repair manual (which covers 2001 solara) and it said nothing about how to remove/replace fog lights...
xcgames
Postby WTF?? » Tue Oct 03, 2006 2:32 pm
No you dont need to remove the bumper.... go under the car and remove the splash guards (big black peices that go from the wheel weel). From there on you will have access to the fogs
Retired... its been fun Image
WTF??
Postby Ruski » Tue Oct 03, 2006 7:18 pm
even eaiser there are two bolts remove them and pull the heat sheild and you will gain room to work unless you want alot then remove splash guard to
Postby WTF?? » Wed Oct 04, 2006 11:13 am
Ruskimafia wrote:even eaiser there are two bolts remove them
what two bolts are you referring to? specify the location
Ruskimafia wrote:and pull the heat sheild and you will gain room to work
I believe you need to remove the black splash guards first in order to even gain access to the heat shields (i didnt even know of any heat shields??)
WTF??
Postby Jon11582 » Wed Oct 04, 2006 1:17 pm
There are no heatshields in that area.
Splashguard is the best and only way. Undo 2 screws for access (They screw in through a clip that clips onto the bumper), or you can remove to remove the three bolts in the back too it for much easier access. Watch out with those bolts, if your cars old and a bit rusty underneath, they strip easy. (I have 3 broken bolts down there).
2000 Black Solara SE
Jon11582
Postby SolAraB » Wed Oct 04, 2006 1:21 pm
Removin the Splash gaurd is the best way to do it...it takes about 5mins with good socket wrench......Kinda off topic but is there a way to actually open up those fog light cases and clean out the inside....just wonderin
SolAraB
Postby krook » Wed Oct 04, 2006 6:31 pm
if you don't want to be on your back the whole time you're mounting your ballasts and whatnot, you can also remove the headlights and grill.
fairly simple if you've done it a couple of times.
krook
Users browsing this forum: Google [Bot] and 47 guests
