SolaraGuy.com • View topic - Suspension Question
Suspension Question
Suspension Question
Postby hipgofast » Sat Mar 15, 2003 11:52 am
Hey everyone, how's it going? I'm new here, so I don't really know what
I'm doing. Anyways I got 2 question on suspension.
1. I was reading that the people that have JIC coils had a problem with squeaking, is that fixed now?
2. Tein is making a coilover suspension for our car, which would be better the JIC or TEIN?
Hope ya'll can help me out.
hipgofast
Re: Suspension Question
Postby Flipside909 » Sat Mar 15, 2003 1:37 pm
hipgofast wrote:Hey everyone, how's it going? I'm new here, so I don't really know what
1) The squeaking problem I think is an isolated issue with installation. Don't quote me on that.
2) It was rumored Tein was gonna make a coilver system...but it hasn't really surfaced since Tein USA brought it to our attention last August at the big Toyota/Lexus meet we had in Carson. Which would be better? Both make great coilover systems, but JIC FLT-A2's are the only coilover system that you can lower without losing suspension travel. And the only available one out right now is the JIC so yes, the JIC is your only choice to date.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Guest » Tue Mar 18, 2003 8:05 am
B & G suspension makes a full coilover system for the solara, with a drop of up to 3.5 inches. the only thing is that i dont know if the damper has adjustable setting to tweak the ride quality. but i still think the JIC is the best, but expensive
Guest
Postby 20SoLaRa02 » Tue Mar 18, 2003 11:34 am
what do you mean by losing suspension travel?
thanx
20SoLaRa02
Postby Flipside909 » Tue Mar 18, 2003 8:10 pm
thanx
Your oem strut, tokico and trd/bilstien units travel exactly the same distance up and down on oem springs. When you put them on lowering springs, you have less suspension travel for your struts to move up and down. With a conventional coilover system, you lower your car, the more compressed the spring goes down and the shock piston's travel shrinks with it. The travel i'm refering to is how much movement the shock absorber has as the ride height is decreased.
www.clublexus.com
Flipside909
Postby STR8PYP » Wed Mar 19, 2003 12:50 pm
The noise from the JIC coilovers is inherent in their design. They use solid metal pillow ball joints, and these are designed to move around like your shoulder socket. Thing is, it's metal on metal, so it makes a clanking noise. Doesn't decrease performance, but it does get annoying to listen to.
Tein won't come out with anything...I'll buy a round of drinks if they do.
SC
STR8PYP
Postby Vampire » Thu Mar 20, 2003 1:55 am
I've heard that before and I don't discount that it's a possibility but if that is the case then why don't the front pillowballs make that sound?? Especially since the front suspension carries more weight.
STR8PYP wrote:The noise from the JIC coilovers is inherent in their design. They use solid metal pillow ball joints, and these are designed to move around like your shoulder socket. Thing is, it's metal on metal, so it makes a clanking noise. Doesn't decrease performance, but it does get annoying to listen to.
SC
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby buss-it » Sat Jul 19, 2003 12:03 am
what are coil-overs ? ? ?
buss-it
suspension question
Postby HKSV6SLE » Sat Jul 19, 2003 10:46 pm
I haven't heard much about the coil over options out there...but...i read somewhere recently...that tein is going to make the system for the solara.....if they do make it....i know people who have tein suspension in other car models who say that they're really good...so....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
