SolaraGuy.com • View topic - I FIXED and installed Dats pipe
Postby Midias » Thu Jan 04, 2007 7:54 pm
OK I got it in the nice guys at EJP welding fixed it up for me. After that it went in but it did hit the frame a bit. For the connections to the manifold use FEL-PRO part number 60674 catalytic converter gasket for mercury villager v6 183 cu inch with one bolt hole opened up a bit. For the flanges to the cat and exhaust use FEL-PRO 60679 from a 1985 Mazda V6. You need 2 of each and the Mazda one will NOT work well with the manifold so don't bother trying.
here are pics of repair you should have them tilt the section after the rear flange down a little bit mine is still rubbing a little.
Postby Mcthings » Thu Jan 04, 2007 8:07 pm
Cool man, you're going to love it.
I've had mine installed since the day it was installed and it's working awesome.
Mcthings
Postby JMSinMaryland » Thu Jan 04, 2007 10:13 pm
Mcthings wrote:I've had mine installed since the day it was installed
And what about the day before it was installed :lol:
JMSinMaryland
pipe
Postby NRDriver » Thu Jan 04, 2007 10:56 pm
haha
NRDriver
Postby Akfahad » Fri Jan 05, 2007 6:20 am
cool....can't wait.
Postby Mcthings » Fri Jan 05, 2007 3:39 pm
Haha I mean since the day I got it in the mail.
Mcthings
Postby Midias » Fri Jan 12, 2007 10:11 pm
Mcthings wrote:Haha I mean since the day I got it in the mail.
Well it took about a week but the ECU seems to have accepted things nicely the car is much more enjoyable to drive. Also the sound is awesome.
Postby Akfahad » Sat Jan 13, 2007 7:23 am
^^^Good to know and I've been waiting for a change in sound for a while too.
Postby Mcthings » Sat Jan 13, 2007 12:45 pm
Yeah, sound and everything took about 2 weeks for me
Mcthings
Postby Midias » Sat Jan 13, 2007 1:08 pm
Mcthings wrote:Yeah, sound and everything took about 2 weeks for me
NOW i just need to combine it with CPE on tuesday
Postby Mcthings » Sat Jan 13, 2007 5:02 pm
CPE?
Mcthings
Postby Biggi_e » Sat Jan 13, 2007 5:14 pm
Mcthings wrote:CPE?
custom performance engineering.
pipe
Postby NRDriver » Sat Jan 13, 2007 7:38 pm
well, i finaly fixed my pipe. it not the prettiest job but it does the trick. i got the idea from mideas but i angled it. total cost = 10.38$
i cut the pipe myself using a saws all and had a muffler shop weld it since i dont have the equipment to weld stainless
i used FEL-PRO 60496-1 gaskets. perfect fit. 3 for 12$
NRDriver
Re: pipe
Postby Midias » Sat Jan 13, 2007 8:08 pm
NRDriver wrote:well, i finaly fixed my pipe. it not the prettiest job but it does the trick. i got the idea from mideas but i angled it. total cost = 10.38$
Glad to see you angled it as I suggested. It is a super tight fit with out being angled. I hope your gaskets fit your stock manifold. I used two sizes a smaller id one for the manifold and a larger id one for the highflow cat connection. There is a signifigent difference
