SolaraGuy.com • View topic - TRD steering wheel
TRD steering wheel
TRD steering wheel
Postby edgard » Sat Jan 13, 2007 12:26 pm
Will the cruise control need to be modified with this TRD steering wheel w/o any modification in wiring or anything?
http://newtoyotaparts.com/product/?id=662
edgard
Postby MCOjerry » Sat Jan 13, 2007 5:41 pm
Why would you want a wheel with a non functioning air bag?
Says off road/show use only air bag will not deploy. Dangerous...
Postby lilm » Sat Jan 13, 2007 6:16 pm
have you thought about getting a celicas steering wheel i rember somone has done it and written a tutorial 700+ dollars for something with a non functional airbag seems like a rip and the celicas willl prolly be the look that your looking for
lilm
Postby ThatVietGuy » Sat Jan 13, 2007 7:28 pm
Why the hell would it have an airbag if it won't deploy :-|
ThatVietGuy
Postby edgard » Sat Jan 13, 2007 8:28 pm
Hmm...good pt...maybe i'll just keep my current steering wheel.
edgard
Postby lilm » Sat Jan 13, 2007 10:52 pm
lilm
Postby NeFaRiOuS_SLE » Sat Jan 13, 2007 11:22 pm
MCOjerry wrote:Why would you want a wheel with a non functioning air bag?
Hope it's only a liability issue... Most companies use it as an excuse to get out of court when it isn't properly installed and the guy sues simply because it didn't go off.
Postby Eye8Pussies » Sat Jan 13, 2007 11:32 pm
^ what he said...there is an airbag, and it should work....
it won't throw an airbag code, that's for sure...the spectrabluecam had the blue trd one
Postby MCOjerry » Sun Jan 14, 2007 10:17 am
That Celica wheel looks like the gen 2 wheel...
Re: TRD steering wheel
Postby ---CAMRAZY--- » Sun Jan 14, 2007 11:09 am
edgard wrote:Will the cruise control need to be modified with this TRD steering wheel w/o any modification in wiring or anything?
I had this steering wheel, it did have an actual bag and no modification was needed for the Cruise control, I sold it to a good friend with a Gen3 Camry. And as King aka Pussies stated... It will not throw a Airbag code.
Postby edgard » Sun Jan 14, 2007 9:46 pm
Thanks for the clarification!
edgard
Postby MCOjerry » Sun Jan 14, 2007 9:58 pm
http://newtoyotaparts.com/product/?id=662 wrote:TRD 3-spoke leather wrapped steering wheel,w/SRS air bag, colors available ** OFF ROAD or SHOW CAR use ONLY, air bag deployment will not occur on impact, not suitable for street**
Why does it specifically say the airbag won't deploy then?
Postby Eye8Pussies » Sun Jan 14, 2007 11:04 pm
so then they have no liability if it doesn't work
and I presume that it is also because it isn't DOT approved
Postby MCOjerry » Mon Jan 15, 2007 7:58 am
OK, but that's my point, no airbag...if it doesn't work, then it might as well not be there....why would you want a steering wheel w/o an airbag.
You get in an accident and you could be screwed...plus, you could get sued. What if you let someone borrower your car and they hit something? They get really hurt and sue you because you purposely had no functioning airbag.
I just think it's silly to replace the steering wheel with one not having a functioning airbag...plain silly.
Postby Ian » Mon Jan 15, 2007 10:41 am
lilm111 wrote:http://www.imagestation.com/album/pictures.html?id=2130608840&idx=1
here is spiked mantis.....
talk to him
I have always like this set up. I'm due for a new steering wheel anyways. Where can I find spike mantis? I don't recall him being on this forum in a while, if at all.
Ian
Users browsing this forum: Google [Bot] and 22 guests
