SolaraGuy.com • View topic - universal resonator
universal resonator
universal resonator
Postby xh0rnsb0yx » Sat Jan 20, 2007 12:08 pm
so i was thinking about replacing my resonator with this...
http://cgi.ebay.com/ebaymotors/Performa ... dZViewItem
so what do ya'll think? i think it would fit because i have 2.25" piping, but im wondering if anyone has ever tried something like this?
xh0rnsb0yx
Postby xh0rnsb0yx » Sat Jan 20, 2007 12:10 pm
also would i be able to pass inspection with this on there?
haha cause it says for off road use only and not for emission test...
i think i just answered my own question..
xh0rnsb0yx
Postby SPF 0 » Sat Jan 20, 2007 12:12 pm
I don't know but I would have to think you'd fail inspections with this mod on.
SPF 0
Postby xh0rnsb0yx » Sat Jan 20, 2007 12:19 pm
anyone know of a resonator i could use that would allow me to pass inspections?
xh0rnsb0yx
Postby Midias » Sat Jan 20, 2007 5:47 pm
... dbl post
It will work the resonator has nothing to do with your emissions as long as you don't touch the cat. Check the length first and pipe size. Also you will probably not get much unless you upgrade the rest of the piping and the muffler.
Postby SPF 0 » Sat Jan 20, 2007 7:22 pm
I guess I assumed that you'd modifying your muffler (I don't see what the point is if you don't) and are putting this on from add'l sound absorption.
SPF 0
Postby hskrsolara » Sat Jan 20, 2007 8:02 pm
muffler and resonator will not affect emissions tests...as long as you still have a catlytic converter, you will be fine.
only guys that will hassle you would be the cops, just for having a loud exhaust...however, this is a rare occurance, so I say go for it!
hskrsolara
Postby crispone » Sat Jan 20, 2007 8:59 pm
I've seen "STRAIGHT PIPES" on vehicles around here... rumbling alongside cops...
...still don't know what all this "INSPECTION" business is you guys are worried about... our registrations in my area just say --> EMISSIONS: "N/A" 8)
My Supra runs downpipe diameter (3") straight back... no resonator, no cat, no muffy... yes, it is pretty healthy sounding. (I just ease off-throttle a little, not completely, and can keep a "modest" tone when around cops with it.... cause under many OTHER scenarios, it's a little aggressive around law enforcement for my comfort.)
Yay! Rural Ohio emissions laws!!! :wink:
-crisp :evilbat: :drinking:
Postby xh0rnsb0yx » Sun Jan 21, 2007 6:11 pm
yeah my muffler is modded so i think it will help out a little bit
also the length is 16" long a 4" wide
it says that it fits piping that is 2 - 2.5", and mine is 2.25" so i should be good
xh0rnsb0yx
Postby tacti » Sun Jan 21, 2007 7:41 pm
I have Gen2, so it is not going to be the same as your setup, but i have replaced my catback to 2.5 pipe, with viblant's resonator spec as following
Inlet Diameter: 2.5"
Outlet Diameter: 2.5"
Resonator Size: 4" Round Body, 15.5" Long
Overall Length: 18"
i assume it won't be that much different in size, so the one you are looking at should fit without muchproblem.
good luck.
Tacti
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby xh0rnsb0yx » Sun Jan 21, 2007 8:27 pm
thanks man
hows yours sound?
xh0rnsb0yx
Postby Midias » Sun Jan 21, 2007 8:51 pm
if you going to do something like this get a whole catback and add it in. I would not bother on stock piping. Here is a pic of my first attempt EVER at making a custom exhaust I used an 18 inch long glass pack resonator.
Users browsing this forum: No registered users and 119 guests
