SolaraGuy.com • View topic - Supercharger leak???
Postby _Tyger_Lilly_ » Mon Feb 05, 2007 5:51 pm
k I just got the car and know nothing about mods... the supercharger has a nice loud noise comeing from it and I only get 3lbs out of it - is it low on oil? is it out of oil? is it a bad bearing? my location isnt used to aftermarket so my mechanic is LOST. Can I check the supercharger oil? How?
Sorry guys
_Tyger_Lilly_
Postby RichD978 » Mon Feb 05, 2007 5:54 pm
what kind of loud noise? its supposed to whine.
or maybe the loud noise is the intake?
RichD978
Postby _Tyger_Lilly_ » Mon Feb 05, 2007 5:58 pm
a nasty almoast grinding noise - almoast like when you let an old car run out of oil.....
_Tyger_Lilly_
Postby DatSRBoi » Mon Feb 05, 2007 6:06 pm
Whats your idle? Does it only grind when it idles? If so your car is idle'ing too low.
Postby _Tyger_Lilly_ » Mon Feb 05, 2007 6:10 pm
DatSRBoi wrote:Whats your idle? Does it only grind when it idles? If so your car is idle'ing too low.
and that would make the supercharger grind??
am I supposed to get mpre than 3 lbs pressure?
_Tyger_Lilly_
Postby DatSRBoi » Mon Feb 05, 2007 6:14 pm
When I use to boost stock, my car too only gaved 3 to 3.5 lbs of boost. I find that the location of where the boost port to be a bad spot. Its never 100% accurate to me. SOmetime youll see it go to 3.7-4.
When I brought mine up to 5.5 lbs of boost and run it straight up, My TRD gauge says I am putting 6-7psi spikes........ So yeah its not 100% accurate.
Postby _Tyger_Lilly_ » Mon Feb 05, 2007 6:19 pm
im terrified that the supercharger is low on oil and im gonna kill it -
do you know how to check the oil in it??
_Tyger_Lilly_
Postby DatSRBoi » Mon Feb 05, 2007 7:38 pm
_Tyger_Lilly_ wrote:im terrified that the supercharger is low on oil and im gonna kill it -
Its a long painful work. But the chance of it leaking is 2% out of 100K miles. Dealerships charge you up the butt to change it but me doing it myself cost me only 11 dollars and 2-3 hours of labor and that included changing sparkplugs and bearings while Im at it for fun.......
See if you can find any solara expert members in your area if you do decide to do it yourself and not take it to the dealership.
Postby Akfahad » Mon Feb 05, 2007 8:05 pm
I don't even bother taking my car to a dealership when it comes to supercharger stuff (most often than not, then don't really know all that much about it...which is true in your case). I take my car to a performance shop, they deal mostly with engine rebuilds, mustangs, corvettes, and some imports. They've been awesome so far, try finding something of the like around you and ask them if they've every dealt with supercharger's before.
Also, if your gonna change the oil you need to read this:
http://www.solaraguy.org/viewtopic.php?t=28807&highlight=oil+change
