SolaraGuy.com • View topic - UNDERDASH/ILLUMINATED ENTRY LIGHTS PROBLEM
Postby nemoxfishy » Tue Feb 20, 2007 7:31 pm
I just finished installing my illuminated entry lights and they look sweet..... however..... whenever i close my door and the lights dimms off..... i hear this buzzing sound from the rear speakers.... like radiation sounds or sth ......
how can i fix that ????
nemoxfishy
Postby Akfahad » Tue Feb 20, 2007 7:52 pm
I'm no electrical expert by any means, but check where you placed your grounds. Possibility pros??
Postby anttarz » Tue Feb 20, 2007 7:54 pm
ground problem
anttarz
Postby nemoxfishy » Tue Feb 20, 2007 8:30 pm
which ground ?? i used the varible ground from the door sensor...... and tthe constant ground is just ..... raw metal !!! ......... where is the problem ???
nemoxfishy
Postby NeFaRiOuS_SLE » Tue Feb 20, 2007 11:58 pm
UH OH!!!! You have plutonium lights, and that's the car's Geiger counter! Call your HAZMAT team!
Re: UNDERDASH/ILLUMINATED ENTRY LIGHTS PROBLEM
Postby krook » Wed Feb 21, 2007 12:28 am
nemoxfishy wrote:I just finished installing my illuminated entry lights and they look sweet..... however..... whenever i close my door and the lights dimms off..... i hear this buzzing sound from the rear speakers.... like radiation sounds or sth ......
what's the specs on these "illuminated entry lights" that you have? what did you use to check for the door wire? multi-meter?
krook
Postby nemoxfishy » Wed Feb 21, 2007 5:02 am
crap i threw the boxes away already... but i used the red/silver wire from the tab that controls the door sensors (under the steering wheel).... that is my variable ground b/c wen my doors open... that wire becomes negative......
sigh..... god help me!! lol
nemoxfishy
Postby krook » Wed Feb 21, 2007 12:14 pm
nemoxfishy wrote:schlock-schlock-schlock i threw the boxes away already... but i used the red/silver wire from the tab that controls the door sensors (under the steering wheel).... that is my variable ground b/c wen my doors open... that wire becomes negative......
red/silver???
as far as i know there IS NO red/silver stripe wire in a Toyota. do you mean SOLID RED wire with silver dots?
the proper door negative input wire (which catches both doors) is red/white stripe. and it's around the kick panel area. are you using a multimeter?
krook
Users browsing this forum: Majestic-12 [Bot] and 49 guests
