SolaraGuy.com • View topic - GETTING RID FOG INSIDE ALTEZZA LIGHTS
Postby supercamsol » Mon Mar 31, 2003 10:07 am
HOW DO i PREVENT FOG OR MOISTURE FROM MY TAIL-LIGHTS?
i HAVE 2002 GOT THE ELIIPTICAL LIGHTS OUT AND BOUGHT THE
ALTEZZA CARBON TYPE WHICH LOOKS DARKER AND FITS WELL
WITH THE COLOR TYPE i HAVE WHICH IS GREEN FORREST PEARL.
THE QUALITY OF THE LIGHTS IS LESS THE 100% BUT IT DOES A GOOD
JOB OF MAKING MY GOOD LOOK A LITTLE COOLER---i FEEL THAT THE
COLOR OF THE 2002 MAKES MY CAR LOOK TOO FEMINEN. THE ALTEzza
with dark apperance makes the car look more macho-man ,strong
and fast and so far I have not seen a celica kick my ass yet----in the long run that is. 8)
thank you
supercamsol
i dont know if this will help
Postby mattacosta » Mon Mar 31, 2003 10:22 am
my friend had the same problem with his 93 mustang when he changed the tail-lights, the solution he did was to put silicon around the edges of the tailights, inside the trunk. I don't know how helpful it will be but it is worth a shot,
btw do you have any pictures of the tallights...?
1999 Toyota Solara V6 SE
All Stock... For Now
http://www.cardomain.com/id/99solarama
mattacosta
Postby Blaze » Mon Mar 31, 2003 10:55 am
wow whats up w/ all the caps?! anyways 1 way to get rid of fog would be to get rid of the lights alltogether! but seriously try sealing the edges w/ silicone
Imagination is the hood ornament on the car of creativity.
Blaze
Re: GETTING RID FOG INSIDE ALTEZZA LIGHTS
Postby Flipside909 » Mon Mar 31, 2003 10:58 am
supercamsol wrote:HOW DO i PREVENT FOG OR MOISTURE FROM MY TAIL-LIGHTS?
and fast and so far I have not seen a celica kick my butt yet----in the long run that is. 8)
thank you
First of all, please do not type in ALL CAPS...it's considering yelling. As for ANY aftermarket tails, they are prone to water condensation due to the poor seals that they are made with.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby supercamsol » Mon Mar 31, 2003 11:32 am
sorry-I fogot about the caps
as long as I try to seal everything I should not have a problem.
right?
supercamsol
Postby Flipside909 » Mon Mar 31, 2003 11:36 am
supercamsol wrote:sorry-I fogot about the caps
right?
Not really. Even if you put a good bead of silicone sealant, there are still chances it wont seal properly.
www.clublexus.com
Flipside909
Postby TadS » Mon Mar 31, 2003 2:11 pm
right?
I had the same problem. I gave them a good load of silicon seems to have helped. I get a little condensation every once and a while, especially after I was the car, but it usually goes away pretty quick. Give it a try, it can’t hurt anything. :)
TadS
Postby ironi » Thu Apr 17, 2003 3:40 pm
silicone will work but check for airholes in the back of the casing also.
ironi
Postby Flipside909 » Thu Apr 17, 2003 4:40 pm
ironi wrote:silicone will work but check for airholes in the back of the casing also.
Temporarily. Then you'll be back to square one with the fogging.
www.clublexus.com
Flipside909
