SolaraGuy.com • View topic - HELP!!! Where to put HID ballast placement
Postby un0john0fodg » Sat Feb 24, 2007 8:15 pm
Where did you guyz put the HID ballast on the drivers side? I can't find a place to secure it firmly :cry: HELPPP!!!
un0john0fodg
Postby funboy102 » Sat Feb 24, 2007 8:18 pm
you drive a Gen 1? well, I drive a Gen 1 and I put my driver side ballast right under the battery. It fits snugly right between the battery and the chassis of the car. Just remove your battery, and put it under it
funboy102
Postby Yanks0114 » Sat Feb 24, 2007 10:05 pm
Under the battery. Here are some pics of my install http://travel.webshots.com/album/188391551CUIZyt
Postby Yanks0114 » Sun Feb 25, 2007 12:36 am
A little more info:
There were actually pre-drilled holes that worked almost perfectly for my ballast. I used cable ties to attach it to the car. The cable tie looped through the holes in my frame into the holes in my ballast.
In order to get to that spot, I removed the battery and the tray below the battery.
____
The other side had similar mounting holes, but in this case you'll have to remove the headlight.
Postby un0john0fodg » Sun Feb 25, 2007 2:55 pm
Thx guyz!!!
un0john0fodg
