SolaraGuy.com • View topic - Cluster Problem lights are on all the time
Postby coldspikee » Sat Feb 24, 2007 9:37 pm
So I wanted a brighter gauges so i put in leds wow great they are working great till some burned out. Then i decied to shave the tops off the leds to make the light wider so i can reduce dim spots on my gauge face. OK every thing went well tested it made sure my wires were right then I put the cluster back into my car and they light up Im like great they work waite a min I did not turn them on nor was the switch left on. NO they just stay lit hmmmmmmm why is that I turn the switch no responce sooo now to turn off my cluster I need to turn down the lights till they are off Hope that does not kill my bat b/c its cold and there is a snow storm.
coldspikee
Re: Cluster Problem lights are on all the time
Postby krook » Mon Feb 26, 2007 1:47 am
coldspikee wrote:So I wanted a brighter gauges so i put in leds wow great they are working great till some burned out. Then i decied to shave the tops off the leds to make the light wider so i can reduce dim spots on my gauge face. OK every thing went well tested it made sure my wires were right then I put the cluster back into my car and they light up Im like great they work waite a min I did not turn them on nor was the switch left on. NO they just stay lit hmmmmmmm why is that I turn the switch no responce sooo now to turn off my cluster I need to turn down the lights till they are off Hope that does not kill my bat b/c its cold and there is a snow storm.
dude that is like the longest sentence i've ever read here well actually it's two but i got confused but it seems to me that you simply FUCKED up your LED's i would go ahead and buy some new ones you might have messed them up when you shaved them
krook
Postby coldspikee » Wed Feb 28, 2007 10:11 pm
yeah but i want to know why they wont turn off. the cluster stays on all the time you think its the leds
coldspikee
Postby ClassySolaraGuy » Wed Feb 28, 2007 10:32 pm
LMFAO!
Sounds like you could have wired them to a positive wire that remains "hot" all the time.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby coldspikee » Sat Mar 03, 2007 12:28 am
Only thing i did different was that I put 3 leds per circut insted of 4 to fill the 12 v oh I took it apart and the lead from the harness to the first bulb seem a little burned think I could have burned out a realy or a part on the cluster. To add i messed with it some more I disconnected the leds and ran stock bulbs and nothing works the lights just wont turn on the cluster. It just does not Light, it sucks at night. I checked the Fuse and its still good.
coldspikee
Postby NeFaRiOuS_SLE » Sat Mar 03, 2007 11:57 am
Users browsing this forum: Majestic-12 [Bot] and 49 guests
