SolaraGuy.com • View topic - NEED RIM HELP A.S.A.P!!
Postby ReaDY-SeT-Go » Tue Feb 27, 2007 9:02 pm
hey guys i finally got my rims put in its the same as nates and jeff's... the nexo PX-5 but i got one big problem!!! :cry: my wheels sizes are 225/40/18 and i thoguht i would be fine but my rear wheels are rubbing!!! like real bad when ever i dip in or when im going up a hill... i rolled the fenders in a little with a bat for the rear... and its not rubbing as much but if i dip in on a bump it rubs HARD :( i need some serious help guys... any good advice before i have to end up buying a new set of tires :fadein:
ReaDY-SeT-Go
Postby ---CAMRAZY--- » Tue Feb 27, 2007 9:10 pm
Cut the fenders or roll them all the way........ What offset did you get?
Postby ReaDY-SeT-Go » Tue Feb 27, 2007 9:21 pm
its a +45 offset and +35
ReaDY-SeT-Go
Postby ReaDY-SeT-Go » Tue Feb 27, 2007 9:28 pm
or isnt a 40?? because the size is 225/ 40 /18
ReaDY-SeT-Go
Postby ---CAMRAZY--- » Tue Feb 27, 2007 9:31 pm
The offsets dont change the tire size, Which offset is it? and if they are different in the front/back, which ones are where?
Postby ReaDY-SeT-Go » Tue Feb 27, 2007 9:53 pm
hmmm now that you say it... i think im only rubbing on the drivers side cause i was kinda confused when one of the tires had the tire sticker on and someone wrote "DRIVERS FRONT SIDE" but on the inside of the rim it said "DRIVERS REAR" so i was kinda confused on that 1 tire... and all the rubbing is on the drivers side of the car... but its only on the rear... do you think if i swap the front and rear... it'll help it out?? thanks milt cause this crap sucks :cry: i dont wanna roll my fenders up more without the cuts
ReaDY-SeT-Go
Postby Midias » Wed Feb 28, 2007 8:24 pm
Well to start take them off and put back on the stock untill you figure out the problem then look into a body shop who will do the rolling
Postby ReaDY-SeT-Go » Wed Feb 28, 2007 9:50 pm
hahahhaha i got to fix it... it was the stupidist thing ever hahahah i guess i had different offsets on the wheel but it never showed on the tire so i got confused but i just swaped them out and put them in the right place and everythings fine hahahah i wanna upload pics but i need a USB for the lap top :( thanks for the help guys
ReaDY-SeT-Go
Users browsing this forum: Google [Bot] and 73 guests
