SolaraGuy.com • View topic - Silicone engine cooling system hoses?
Postby scdsolara619 » Thu Mar 08, 2007 12:45 pm
Hi,
I'm looking to upgrade my engine cooling system hoses w/silicone ones, I did a search here but nothing came up. Does anyone know a company that makes them. Thanks for any info.
-Davor
02 SE V6 (S/C) AT
scdsolara619
Postby Mole » Thu Mar 08, 2007 1:31 pm
how does using silicone hoses cool down the engine more efficiently?
Postby PXLpainter » Thu Mar 08, 2007 2:31 pm
I thought silicone INCREASED heat - not a cooling effect! :o
Postby SleeperSolara » Thu Mar 08, 2007 5:29 pm
PXLpainter wrote:I thought silicone INCREASED heat - not a cooling effect! :o
Hahahaha.
Good one.
"Mole" it helps hold the shape when hot coolant is runni'n through it.
Postby lilm » Thu Mar 08, 2007 7:18 pm
its not really a upgrade.....more of a....rice-grade?
lilm
Postby NeFaRiOuS_SLE » Fri Mar 09, 2007 12:57 am
ARRRRGH you beat me to it!
Postby scdsolara619 » Fri Mar 09, 2007 9:40 am
lilm111 wrote:its not really a upgrade.....more of a....rice-grade?
Ha, ha... well then i definetly don't want to to that. I was obviously misinformed (I thought I saw a few high end tuner cars / race cars with those on them, but I may be mistaken). Well then someone should maybe add this "rice-grade" to the "RICE CITATION" that someone posted the other day. Thank for the info, you saved me from ricing my car out. :)
02 SE V6 (S/C) AT
scdsolara619
Postby Midias » Fri Mar 09, 2007 9:59 am
I know all cop cars run silicon hoses but why I am not sure.
Postby SleeperSolara » Sat Mar 10, 2007 10:10 am
Like i said before.
Silicone hoses hold their shape better than rubber hoses under heat.
Postby trdkamuri51o » Sat Mar 10, 2007 10:16 am
there is a company out there that makes some sick made clear hard plastic hoses with couplers.. ill get some info tonite.. the rep is evildav from scikoticz...
trdkamuri51o
Postby SleeperSolara » Mon Mar 12, 2007 6:41 am
trdkamuri51o wrote:there is a company out there that makes some sick made clear hard plastic hoses with couplers.. ill get some info tonite.. the rep is evildav from scikoticz...
That would be bad @$$.
