SolaraGuy.com • View topic - RSX Wheels
RSX Wheels
RSX Wheels
Postby badjura » Sat Mar 24, 2007 7:32 pm
Did a quick search - couldn't find anything
There are some cheap 16" RSX wheels that I can pick up locally
From what i can find out it looks like they have the same bolt pattern and offset as the 16" solara stockies
Question is: do they actually fit and can I just bolt these on without spacers?
thx guys
2002 SE 2.4_TRD Kit - BBS
badjura
Postby woa_its_j3ff » Sat Mar 24, 2007 8:07 pm
looks arent anything. everything with a 5 lug will LOOK as if itll fit.
i checked on tirerack. rsx has 5x114. ours are 5x114.3 not exactly sure if it'll fit or not. you wont need spacers for these tho man. sorry if im not much help, if anything go to a local tire shop like discounttire or some store like that and ask if the swap will work. good luck and if it works, post pics man. it'll be ......
interesting
to see honda rims on a toyota.
Postby funboy102 » Sat Mar 24, 2007 8:12 pm
^^^, yeah, check out what he said. Make sure bolt pattern is the same, and make sure that the center hub is the same size also. And for sure, if you do get it, take off the Acura center caps...
funboy102
Postby badjura » Sat Mar 24, 2007 8:25 pm
I was going by this:
http://www.discountedwheelwarehouse.com ... erence.cfm
RSX 01-01 5X114.3 12mmX1.5 70.3 H
CAMRY SOLARA 99-on 16 X 6 5X114.3 12mmX1.5 60.1 H
Although the CB is 70.3 on the RSX and 60.1 on the Solara - whatver that is - lol
badjura
Postby woa_its_j3ff » Sat Mar 24, 2007 8:29 pm
I asked one of my friends at a DiscountTire, he said that a few months back when he used to work there he did see a camry he said it might've been an 01 with a rsx rim swap done to it as well. i don't see then why it wouldnt work. best bet is still ask discounttire directly. dont want to purchase the wheels ASSUMING it'll fit then in the end you just have an extra set of nonfitting wheels in your garage.
Postby Jon11582 » Sat Mar 24, 2007 8:43 pm
I assume CB is center bore. 60mm and 70mm sound right for that.
Looks like the RSX is bigger, so if it is Center bore, you will need a hubcentric ring the exact size (60 inner diameter, 70 outer diameter) for the two for a good fit.
But whats the point of putting RSX rims on a Solara anyways?
2000 Black Solara SE
Jon11582
Postby woa_its_j3ff » Sat Mar 24, 2007 8:49 pm
Jon11582 wrote:I assume CB is center bore. 60mm and 70mm sound right for that.
just liek asking PXLpainter wuts the point of g35 wheels on his solara. it's all about personal taste.
Postby funboy102 » Sat Mar 24, 2007 8:58 pm
^^^^ yep, listen to what he's saying... You will NEED those hubcentric rings to make it fit properly.
and, what's wrong with the RSX wheel? haha, I mean, they're just your regular run of the mill 5-spoke rims right?
funboy102
Postby CamryOnBronze » Sat Mar 24, 2007 9:00 pm
i knew a guy that worked at discount tire and he tried to sell me his rims off of his rsx- so i think they should fit.
Postby Sebas007 » Sat Mar 24, 2007 9:04 pm
Just for your info...bolt pattern 5X114 doesn't exist...maybe but just in the country of lazy people ;)
it's 114.3mm that equals to 4.5"
Postby Jon11582 » Sat Mar 24, 2007 9:29 pm
Yea thats my point. They are just run-of-the-mill, so I dont see a point in getting these. Not to mention another car manufacturer's emblem sitting on the hub.
G35 stocks are much nicer than "run-of-the-mill" stocks.
Also, it doesn't sound like a case of personal preference; it sounds like a case of "I can a good deal on them and I got the upgrade itch".
Another thing - RSX stocks are 205/55/16. Solara Gen 1 rides on 205/60/16s. If you use the tires that come on it, it means your odometer will be off by over 3%, which is outside the normally acceptable difference in diameter from stock.
Jon11582
Postby funboy102 » Sun Mar 25, 2007 6:56 pm
^^^^ true, even if you get those RSX rim's, you gotta get new tires, 205/60/16's like the stock's. And also, just to let you know Jon... the Acura center caps CAN be removed
funboy102
Postby badjura » Mon Mar 26, 2007 11:07 am
he sold them as i was on my way out there :x
thx anyways
badjura
