SolaraGuy.com • View topic - got a turbo!!!
got a turbo!!!
got a turbo!!!
Postby NRDriver » Sun Jun 24, 2007 10:05 pm
i know i posted my car for sale but i couldnt sell it. My shop, Pacific Northwest transmissions has a 950HP dart at the dragstrip and we are currently building a caprice with a corvette engine (old cop car) to race. with all this going on i decided i need to step up with my car. so my boss gave me a turbo and we are gonna do it all our selves. i figure this will produce more HP than a supercharger and if i do it myself it will be cheaper. i took a close look at this setup and it looks like it wont be too hard. IM STOKED!
http://www.solaraguy.org/viewtopic.php?t=19057&highlight=turbo
NRDriver
Postby woa_its_j3ff » Sun Jun 24, 2007 10:06 pm
gl with it man. if it pulls through , let's see some numbers! :cool: and vids, and pics. wahoo.
Postby Akfahad » Mon Jun 25, 2007 5:30 am
good luck with the project...you'll be the third ? I believe??
Postby Paladin06Greg » Mon Jun 25, 2007 5:43 am
Remember you got stock internals and it won't take much for them to go BOOM!!!
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Mon Jun 25, 2007 10:02 am
Good luck man.
Postby Astro » Mon Jun 25, 2007 11:16 am
Good luck! Beef up your internals so you can you some kind of reasonable boost - not a pathetic amount like us s/c'd folks...
boost
Postby NRDriver » Mon Jun 25, 2007 6:38 pm
i plan on running only 5 lbs of boost at first. if it all works well and i actually finish this project i will build the engine for more boost
NRDriver
Postby Sebas007 » Mon Jun 25, 2007 6:51 pm
I'm trying to learn ALL the basics around turbo setup, you have such a luck of opportunity to do what I dream about...do my own turbo setup (working :P )
Good success with your "too cool" project !!
Postby Patrik » Mon Jun 25, 2007 8:16 pm
im actually in the process of building my own turbo kit too... using this to guide me a little bit with the piping... turbo i want to use is t3/t4 since i dont want to change the internals yet since ill be swapping to a 3mz block this winter
good luck with the turbo setup :)
1999 SE V6 5 speed SOLD
Patrik
Postby Turbosolara » Mon Jun 25, 2007 8:25 pm
good luck guys. just make sure you have a daily beater in case things doesn't go smoothly
Postby CorCamrySE » Mon Jun 25, 2007 8:37 pm
sounds like a cool project...keep us posted
MCV30 - 1MZ-FE
2003 Lexus ES300
CorCamrySE
Postby dominoSLEV6 » Mon Jun 25, 2007 9:36 pm
Paladin06Greg wrote:Remember you got stock internals and it won't take much for them to go BOOM!!!
Yes it is not that hard to piece together a turbo kit. No it is not going to be very worthwhile unless you build your internals. TRD SC or internal build. I'd say if you're going for it do the damn thing at once, if not get a supercharger until you're ready to. Really not worth it without the built bottom end IMO.
-chris
dominoSLEV6
Postby ProRally Codriver » Mon Jun 25, 2007 9:50 pm
There is a lot more needed than just the turbo and I'd build from scratch to do internals cause you might as well at least upgrade the head gaskets before boosting. Boost is like crack and it won't be long before 5lbs ain't enough and you'll be wanting more. 5 lbs isn't worth the trouble. I run 20lbs in my streetcar.
Put on your shopping list:
Intercooler
Wastegate
BOV
Boost controller
Boost gauge
Larger injectors
Upgraded fuel pump
Adjustable fuel pressure regulator
Fual pressure gauge
Colder plugs
AFC piggyback
Low profile radiator fan
Plumbing for oil line into oil pan
Good idea to have:
Alum radiator
ProRally Codriver
internals
Postby NRDriver » Wed Jun 27, 2007 6:18 pm
i decided to build the internals first since it makes sense.
NRDriver
Postby crispone » Wed Jun 27, 2007 6:32 pm
ProRally Codriver wrote: Boost is like crack and it won't be long before 5lbs ain't enough and you'll be wanting more. 5 lbs isn't worth the trouble. I run 20lbs in my streetcar.
^^^ HA HA!!! So true. LIKE CRACK! :changes:
(I don't know exactly what that is like... but I'm assuming it's ADDICTIVE as HELL! 8) )
...oh yeah... I TRY to keep it at about 15lbs... good, but I'd do MORE if I could get my HANDS ON IT! (safely? ...you know... like doing CRACK SAFELY! 8) )
Users browsing this forum: Google [Bot] and 53 guests
